Steer hardening after lifting
Discussion in '2.5 Gen Tundras (2014-2021)' started by herchi79, Jan 5, 2019.
  1. Jan 5, 2019 at 12:23 PM
    herchi79
    herchi79 [OP] New Member
    Tundra 2018 1794 ed.
    N/a
    Hi, I recently lifted my Tundra 2018 with only 2'' in the front, looks great by the way, but I noticed the steering changed a tiny tiny bit. Now is a little bit harder to steer the wheel. Probably others would say in unnoticeable because it is really a tiny tiny change, but enough for me to notice it. Is this normal ? Have this happen to anyone here ?
    Thanks
  2. Jan 5, 2019 at 12:31 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Have you had it aligned?
    Stormtrooper81 and 15whtrd like this.
  3. Jan 5, 2019 at 1:12 PM
    herchi79
    N/a
  4. Jan 5, 2019 at 1:17 PM
    Grumpy Uncle
    Pat
    CO
    Bigger tires? Bigger meat more resistance.
  5. Jan 5, 2019 at 1:23 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    When I lowered my accord the same thing happened. Lifting or lowering a vehicle changes the suspension and steering geometry, so tougher steering is a side effect.
  6. Jan 5, 2019 at 3:42 PM
    Philogynist
    Philogynist New Member
    NY
    Best thread title this year.
  7. Jan 10, 2019 at 12:29 PM
    lamikela1
    lamikela1 New Member
    Michael
    2019 Silver Sky Platinum Tundra 4X4
    Revolver X4 cover, Bedrug, Pocket Flares. Previously owned... '86 Hilux, '94 4-Runner '95 Taco, '05 Taco
    Did you add any spacers or a different wheel offset? Is so your scrub radius may have changed and is causing the tire to dig into the ground harder when turning. Otherwise it's probably just the larger tires.
    Stormtrooper81 likes this.
  8. Jan 10, 2019 at 12:39 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Stiffer springs can cause stiffer steering also if you change them
  9. Jan 10, 2019 at 1:25 PM
    15whtrd
    15whtrd Mr. Blonde
    I’m not too good at understanding alignment even though I’ve read the best threads on it. But if it’s not where the factory specs are it will change the feeling. Caster camber and toe all come into play.
    HappyGilmore and Stormtrooper81 like this.
  10. Jan 11, 2019 at 1:03 PM
    lamikela1
    Michael
    Check this out. It will show you what changes in your steering geometry when you make changes to the front end.
