Steel front bumper
Discussion in '1st Gen Tundras (2000-2006)' started by Girllovestrucks, Aug 13, 2019.
  1. Aug 13, 2019 at 6:04 AM
    Girllovestrucks
    Girllovestrucks [OP] New Member
    Nancy
    1st gen tundra
    None yetY
    I am replacing my bumper cover for a steel bumper in my 2004 tundra. But Im havinkg all kinds of issues trying to figure out how/wgere the 2 brackets attach to my truck and what size bolts to use. Any suggestions would be so appreciated.
    Thanks!
    Girllovestrucks
  2. Aug 16, 2019 at 5:39 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    You're trying to put which bumper on? Like the 00-02 metal bumper? Or an aftermarket bumper? Pics.would.help.
    mscribellito likes this.
  3. Aug 17, 2019 at 5:07 AM
    Girllovestrucks
    Nancy
    1st gen tundra
    None yetY
    Oem bumper and finally figured out that the brackets attach to the reinforcement bar. Talked to Roman and got bolts coming..
  4. Aug 19, 2019 at 7:34 AM
    mscribellito
    mscribellito New Member
    Michael
    2006 White Regular Cab Tundra
    Is the metal bumper a direct swap (assuming you have all hardware/bracketry) for the bumper cover? I have a 2006 with some front and rear bumper issues. Was contemplating adding the steel bumpers from the earlier trucks.
  5. Aug 20, 2019 at 4:41 AM
    Girllovestrucks
    Nancy
    1st gen tundra
    None yetY
    My bumper is an oem but does not come complete with everything you need. I used thesubassembly diagram from toyotaofcoopsprings for steel bumper to make sure had all parts. The one issue I am having is the left/lright mounting bracket bolts. There is no size given so I asked coolsprings got the bolts yesterday but were too small. I found that the bolt size is the sane as that used on the reenforcment bar, size 14 fine thread. Once I receive the bolts I can finally put together.
  6. Aug 20, 2019 at 6:32 AM
    Girllovestrucks
    Nancy
    1st gen tundra
    None yetY
    It is a direct swap until you get to the mounting brackets
