Steel Braided Brake Lines
Discussion in 'General Tundra Discussion' started by Air2Ground, Dec 27, 2017.
  1. Dec 27, 2017 at 7:03 PM
    Air2Ground
    Air2Ground [OP] This summa bitch is gonna scream!
    Michael
    Herndon, Va
    Building this brick by brick.
    K&N CAI Series 77 Banks Monster Exhaust Stage 2 Icon suspension SPC UCA's Coachbuilder Shackles +2's and poly bushings Coach Builder Front Bump Stops Steel Braided Break Lines by ToyTec Icon 6 speed 17" Wheel 315/70/17 BFG Goodrich KO 2's Tekonsha Trailer Brake AirRaid Throttle Spacer Slotted/Drilled Rotors by StopTech w/ stock pads Pioneer AVIC 8100 Receiver/Focal Component Speakers (4) JL Stealthbox JL Audio HD series amps 500/4 and 750/1. Complete Dynamat of cab Python Alarm/Remote start Linex sprayed front billet grille with "T" logo Linex sprayed bed Retrax Bed Cover 6" powder coated step bar High End 3M 5% tint PIAA Fog Lamps DIY Superman trailer hitch "S" WeatherTech Mats TRD Shift Knob Upcoming Mods: debagging Future mods: Front/Rear bumper winch supercharger and rebuild (blueprint) engine new lights in and out headlight/taillight combo Skid plates Cat Back Exhaust and Long Tube Headers.....? (Still deciding most optimal way) I NEED A SOLID TUNE!!!! Etc....
    Hello,
    I am looking for some steel braided break lines. I am doing this while I'm doing my suspension lift as its a good time. I bought some Stoptech ones and they are too short. Does anyone know which brake line to use for lifted trucks?
  2. Dec 27, 2017 at 7:15 PM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    How tall are you going. Everything I've seen up to 6" lifts say just use stock length lines. You un-bold the rear from the diff (longer bracket) and had plenty of play with the fronts for my level kit. When i planning the SS lines I found longer ones I think on autoanything.com? I'm sure somebody like Dirtydeeds.com or SDHQ could give you better direction.
    Air2Ground[OP] likes this.
  3. Dec 27, 2017 at 7:22 PM
    Air2Ground
    Michael
    Herndon, Va
    I'm only doing a 3.5" stage 2 icon lift. This is what I purchased from Stop Tech http://www.autoanything.com/brakes/75A4620A0A0.aspx
  4. Dec 27, 2017 at 7:25 PM
    triharder
    Jake
    Southern, Maine
    2010 RWB Black
    And they are too short? I ordered the same thing for the 2010 when I did the conversion this fall. Besides loosening that the rear bracket I was close but good at length in the rear. I don't remember problems in the front. (Actually now that I remember better with full travel of the rear I was thinking longer would have been better).
    https://www.amazon.com/Goodridge-Extended-Toyota-TUNDRA-Package/dp/B007ZG1VZ0 4" longer?
  5. Dec 27, 2017 at 9:01 PM
    TheBeast The Beach
    Toytec or sdhq
  6. Dec 28, 2017 at 7:57 AM
    Air2Ground
    Michael
    Herndon, Va
    Thank you guys. Ordered from ToyTec
    ColoradoTJ and NewImprovedRon like this.
  7. Dec 28, 2017 at 8:04 AM
    SoCalDave
    SoCalDave New Member
    Dave
    2016 DC 4x4
    Crown automotive can make them in any length you need. I went with a full set from them. My rear lines were a bit short at full droop even after extending the rear diff bracket.
  8. Dec 28, 2017 at 8:09 AM
    For custom brake jobs I use Speedway Motors in Kansas.
    Good to know Toytec has this option. Like a one stop shop for a Toyota.
