Stealership Says I need a new Battery
Discussion in 'Electrical' started by alpinepro4, Nov 3, 2023.
  1. Nov 3, 2023 at 11:55 AM
    alpinepro4
    alpinepro4 [OP] What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    I was at the Dealership getting a few things done and they did a routine test on my battery. According to them I need a new battery. Battery starts the truck just fine and all guages work fine. I assume they are trying to pull a fast one? That seem correct.
    According to their test battery tested at 520CCA and they say should be around 710CCA. Votage is 12.59V which seem perfect.
  2. Nov 3, 2023 at 12:00 PM
    alpinepro4
    Pat
    Right, you measure off of Voltage. What are they measuring?
  3. Nov 3, 2023 at 12:04 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Buy a cheap auto battery load tester and know for sure yourself.
    It's a good item to have anyways.
    As for "that sound right". I don't trust anyhing a dealer tells me. My local mechanic, yes (usually), but not the dealership.
    WILLINH and Backslider like this.
  4. Nov 3, 2023 at 12:05 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    I wouldn't trust the dealer to tell me my truck was on fire or not.
    excelw, Mike59, rockmup and 5 others like this.
  5. Nov 3, 2023 at 12:11 PM
    alpinepro4
    Pat
    Time to buy a battery load tester. Harbor freight one should get the job done. I wasn't going to buy a battery from them. I can see how people get sucked into their smoke show if you haven' a clue on what going one.
    Mike59 and Leo's first like this.
  6. Nov 3, 2023 at 12:15 PM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    I was at the dealership and I swear they tried to charge an old man 29.99 to clean his battery.....wtf
    BravoDeltaRomeo likes this.
  7. Nov 3, 2023 at 12:18 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    12.6 volt is a healthy battery. If it drops down to 12.3, then that means there’s a bad cell. It sounds like some sound advice from above to buy a HB load tester. You could also probably get it load tested for free at a NAPA.
  8. Nov 3, 2023 at 12:55 PM
    alpinepro4
    Pat
    I probaby could, but I need an excuse to buy another tool:D
  9. Nov 3, 2023 at 12:55 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    The shop where I carry my truck for service (mainly oil changes) would tell me I needed a new battery every time I went in. I finally reminded them that Tundras charge at a lower rate than most, and that the lower voltage was why you have to use the GM diode if you use an AGM battery. I got a slightly blank look for a moment, then and "OK" and no battery recommendations since then.
    FrenchToasty likes this.
  10. Nov 3, 2023 at 1:58 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Dealership here is also an ironman dealer and said I should upgrade my suspension to ironman lol
  11. Nov 3, 2023 at 2:04 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Voltage is not the only measure of the health of a battery.
    rockmup and BravoDeltaRomeo like this.
  12. Nov 3, 2023 at 2:16 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    They have a fantastic cot. Wonder if you could get me a deal? Not sure I need another one.. but bunk beds in the tent would be cool :rolleyes:
    reywcms[QUOTED] likes this.
  13. Nov 3, 2023 at 2:26 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    I use one like this. It was about $40 Canadian and stay in my truck.
    KZYEE KS21 Auto Battery Tester, 12V CCA Car Battery Load Tester Digital Analyzer for Vehicle Battery Health, Cranking and Charging System https://a.co/d/bRoNSHg
  14. Nov 3, 2023 at 2:31 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    True, Also measure cranking amps and cold cranking amps. Back in my Advance auto part days, I would see batteries at 12.5 or more volts and still only have 200 CCA's and rated at 700 CCA's.
    520 CCA's would crank a truck at 80 degrees but would have a hard time cranking a truck at 0 degrees
    WILLINH likes this.
  15. Nov 3, 2023 at 2:32 PM
    alpinepro4
    Pat
    Hmm.. the truck will be cranking at well below 0 this winter. I guess that will be the true test.
  16. Nov 3, 2023 at 2:44 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Is it original battery?
  17. Nov 3, 2023 at 4:30 PM
    alpinepro4
    Pat
    Yes the original battery, so it's over 5 years old. I tested the battery with volt meter when starting the truck. Battery at 10.1 volt when starting. For 50 degrees proabably not a problem but at negative temps I think I am hosed. Looks like I do need a new battery. F**k'ers where right.
    Leo's first and TXBrit like this.
  18. Nov 3, 2023 at 7:12 PM
    alpinepro4
    Pat
    Looking at geting Napa Legend Premium battery 36 month warranty. Has 750 CCA.That will fire it up at -20. Anyone running this battery? Nearest Costco is 70 miles away, if it wasn't so far I would buy from Costco.
  19. Nov 3, 2023 at 7:30 PM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    My remote start killed my factory battery. During Covid, I let my truck sit for 3 months un-used and the stock battery got smoked. Used a Noco repair and recharge but replaced in 2022 on a 2018 truck. the stock battery isnt any bigger than my tacoma. Plan to replace with an AGM if it ever lets me down again. The Odyssey AGM in my Tacoma is great, will be the next progression for my tundra.
  20. Nov 3, 2023 at 7:45 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Get yourself a multi meter and check your battery in the morning after leaving your headlights on for 2 minutes. Read the voltage as you turn on the truck. If it goes below 10v you need a new battery
    Randy Morton likes this.
  21. Nov 4, 2023 at 7:05 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I replaced my stock battery last year as it had 500cca when tested it was 3 1/2 years old.I put in a trustart battery. Just replace the battery in my daughters 2019 pro with a Napa 27F and was surprised it was stamped made in Mexico.
    Leo's first likes this.
  22. Nov 4, 2023 at 9:50 AM
    alpinepro4
    Pat
    Did what you said this morning. I got 9v cold start. Looks like new battery.
  23. Nov 4, 2023 at 10:01 AM
    stuckinohio
    Mark
    oHIo
    2018 SR5 Crewmax
    If you plan to shop around on a battery, i would recommend:
    Costco- Interstate battery line
    Batteries Plus- X2 Power AGM
    4WP- Odyssey AGM
    Some people swear by the NAPA gold batteries as well.
  24. Nov 4, 2023 at 10:19 AM
    alpinepro4
    Pat
    Going NAPA Legend, I have one in my Audi S4 wagon. Been an excellent battery.
  25. Nov 4, 2023 at 10:35 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    The dealership replaced my battery in July 2022 after my truck sat on their lot waiting for cat parts for 8 months.
    It is a TrueStart 84-month battery.
    It seemed fine for about a year, but now the truck starts with a little hesitation.
    Kinda like when I had a 4 year old battery and it was time for a new one.
    My remote start/alarm app will also send a low battery alert sometimes when I shut the engine off.
    Not every time I shut it off, but 1 out of 10.
    Never had this issue with my Interstate batteries..
    Maybe I'll buy one of those load testers..
  26. Nov 4, 2023 at 9:51 PM
    MadMaxCanon
    I just got one from Costco, non agm, great price and warranty.
