Startup Hesitation
Discussion in '2.5 Gen Tundras (2014-2021)' started by dru741, Dec 2, 2020.
  1. Dec 2, 2020 at 4:58 PM
    dru741
    dru741 [OP] New Member
    2014 Silver Tundra SR5 TRD CM
    So, I have 2014 TRD Crewmax with about 180k miles. Here recently I have noticed that when I first start the truck, it seems like it has a hesitation to start, but once it starts, there is no issues. Any ideas?
  2. Dec 2, 2020 at 5:04 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    When you say slow to start, does it turn over slowly and then catch and start? If so possibly battery. If it turns over fine and takes a while to start it could possibly be a fuel pump issue. There’s a big recall for fuel pumps. I’m not sure of the year models affected. You can put your VIN in on Mama Toyota’s website and check.
  3. Dec 3, 2020 at 5:10 AM
    dru741
    No it cranks fine, battery was replaced last year. I was thinking it could be fuel pump issue but, it only does it when it’s cold. I would think if it was fuel pump, wouldn’t it be constant and have issues while running too? I will check on the recall today.
  4. Dec 3, 2020 at 5:55 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Might check your battery again. I know it’s only a year old but my Toyota Sienna did the same thing with a relatively new battery (2 yr old), and eventually wouldn’t start. New battery fixed it.
    equin likes this.
  5. Dec 3, 2020 at 7:37 AM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    Post a video. Much easier to diagnose.
  6. Dec 3, 2020 at 6:39 PM
    dru741
    should be able to watch it there.
  7. Dec 3, 2020 at 6:42 PM
    dru741
    here is the 2nd start just a few seconds later.
  8. Dec 3, 2020 at 6:44 PM
    dru741
    double checked today, no recall on my truck for fuel pump.
  9. Dec 3, 2020 at 6:50 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Somewhat minor stumble/miss for less than a second, not bad. Do you run some fuel/alcohol treatment through it from time to time? Then there's always MAF cleaning, intake cleaning. Checked plugs for clues?
    glowblue likes this.
  10. Dec 3, 2020 at 6:56 PM
    Seems almost normal from what I can hear
  11. Dec 3, 2020 at 7:05 PM
    GravityGear
    Aurora, CO
    Eh, not terrible. I would first do some basic maintenance. When was the last plug change? Maybe clean the maf and the throttle body. Run a couple of tanks with injector cleaner.
  12. Dec 3, 2020 at 7:16 PM
    dru741
    Plugs are original, I thought it was that at first, but in my experience, plug issues are noticeable while running too. I run Lucas Fuel treatment regularly, every other fill up or so. I haven’t dug too much into the issue but I plan to look a little deeper tomorrow when I get to my shop. It does startup, but this new hesitation as me worried a bit. Never done that before.
  13. Dec 3, 2020 at 7:17 PM
    glowblue
    VA
    I would also check the battery (I sound like a broken record)...just seems like you’re not getting the cranking power to turn the engine over quickly.
    equin likes this.
  14. Dec 3, 2020 at 7:18 PM
    dru741
    I’ll have it checked tomorrow as well. I stated earlier it is a fairly new battery, but that don’t mean squat. I have had brand new parts be bad.
  15. Dec 3, 2020 at 7:19 PM
    GravityGear
    Aurora, CO
    Regardless, change that noise. They've got 180k on them. IIRC, the plug interval is 100k.
    JLS in WA, T-Rex266 and TheBeast like this.
  16. Dec 3, 2020 at 8:11 PM
    dru741
    true statement, recommendations for plugs?
  17. Dec 3, 2020 at 8:22 PM
    TheBeast The Beach
    oem imo
    JLS in WA and GravityGear like this.
  18. Dec 3, 2020 at 8:27 PM
    GravityGear
    Aurora, CO
    OEM Toyota
    Denso SK20HR11
    Denso IKH20TT
    Leave the gimmick plug BS at the door. You don't need 8 ground arms. Also, don't gap the iridium stuff, you'll destroy the electrode tip.
    TheBeast likes this.
  19. Dec 7, 2020 at 2:51 PM
    dru741
    Changed the plugs today, Put in some new Denso IKH20TT. Problem still persists. Only code that shows in history is P1604 Startability Malfunction. Saturday, I started it for about 10 secs, turned it off. Attempted to restart and it took 3 starter cycles to start it successfully. After It runs about 5 mins, it starts up like a champ.
  20. Dec 7, 2020 at 3:03 PM
    TheBeast The Beach
    does it only happen during cold weather ? and how about after that first start in the morning, does it still happen during the day ?
  21. Dec 7, 2020 at 3:07 PM
    dru741
    Im not sure if it is only during cold weather or not, it started having problems a couple weeks ago. Average temp here now is about 30-40*F. It does continue during the day after it has sit for a few a few hours.
  22. Dec 8, 2020 at 10:51 AM
    dru741
    Here is a start from this morning after it sit overnight. Outside temperature is about 25*F. You can tell the hesitation and sputter much better in that video. It almost died but finally picked up to idle.
  23. Dec 8, 2020 at 11:08 AM
    GravityGear
    Aurora, CO
    If it starts fine after running for 5 minutes, it sounds like you're losing fuel pressure. The pressure will drop while it sits then the pump has to bring it back up to pressure during the start sequence. While it's doing that the injectors may just be dribbling fuel until it's back up to pressure.
  24. Dec 8, 2020 at 5:39 PM
    dru741
    The next issue is after it starts and idles for 10-15 seconds, fuel pressure should be stable and fully pressurized. In my case, I can start it and after the 10-15 stabilization idle, shut it off, then restart, it still has a sputter and it seems to get progressively worst with each start in that short period.
  25. Dec 9, 2020 at 10:59 AM
    fytedapowr
    fytedapowr New Member
    Jake
    Austin TX
    '15 1794 4x4
    Bilstein 6112/5160, CB +2 shackles, SPC UCA's, CB bumper shims, 35's
    Flex fuel engine?
  26. Dec 9, 2020 at 11:14 AM
    dru741
    No, not flex fuel
  27. Dec 9, 2020 at 11:21 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Your issues really remind me of what my SC400 does early in the morning and when its cold... It has a cold temperature injector which is used only during certain temperatures, and does something similar. Other times it hesitates, so I sprayed some throttle body cleaner and its been good, I also rebuilt my IAC valve changing out the bearings and its been starting and idling good consistently..... I would think its an IAC valve, may need a couple sprays of a throttle body cleaner....
  28. Dec 9, 2020 at 3:14 PM
    dru741
    So, I’m still trying to diagnose the issue. Took it to a shop today and spent sometime with their fancy scan tool. Every sensor we checked was working correctly, battery checked good, no codes except P1604 startability malfunction. Still clueless to what the problem actually is. Going to clean up the throttle body and look at the grounds next to see if it persists.
  29. Dec 10, 2020 at 7:10 AM
    Breathing Borla
    Northern Illinois
    my truck is doing the exact same thing right now
    head scratcher
  30. Dec 10, 2020 at 7:24 AM
    blackdemon_tt
    Any chance its the fuel pump relay going bad??
    HulkSmurf14 likes this.
