starts then starts 2001 tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Molly2, May 13, 2021.
  1. May 13, 2021 at 12:59 PM
    Molly2
    Molly2 [OP] New Member
    2001 Toyota Tundra small engine
    My Tundra (small 4. engine) starts great. Then it immediately stops. I've had the alternator checked at two places. Both say it's good. ANY SUGGESTIONS? I use my truck for work. Hate to lose it. It's got 200,000 miles, but for a Toyota, it's just getting started.
  2. May 13, 2021 at 1:04 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    What happens if you immediately restart it? Do you have to wait a while before it'll try to restart, or does it start and die if you try right after it dies? I'd check the fuel pump and filter first.
    15whtrd likes this.
  3. May 13, 2021 at 4:26 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    (Monotonic voice) Data. Must have more...data...
    bmf4069 likes this.
  4. May 13, 2021 at 10:36 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    Have you checked your throttle body? If it’s dirty give it a good clean up.
  5. May 14, 2021 at 12:57 AM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    I agree with @Randy Morton.
    check fuel pressure and make sure it falls in the correct range.
    Start and stall is one symptom of week fuel pressure
  6. Jul 3, 2024 at 7:23 AM
    DEuser
    DEuser New Member
    Our 2014 Tundra with about 100,000 miles just stopped while driving down the road. Thought it was the fuel pump which the mechanic replaced. Truck ran for about 5 minutes and cut off again. The dealer replaced the ECU (electronic control unit), a computer board for the fuel pump. We have the tow package. ECU = $900 repair plus the $800 fuel pump that we probably didn’t need. Anyone else having problems like this?
  7. Jul 3, 2024 at 9:55 AM
    shifty` In South Dakota Trouble ain't hard to find
    This is the 1st gen (2000-2006) Tundra subforum. You may want to ask in the 2.5 gen forum: https://www.tundras.com/forums/2-5-gen-tundra-parts-marketplace-2014-2021.29/
    Create a new thread over there, I guess?
  8. Jul 4, 2024 at 6:22 AM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    2001 Tundra SR5 Access Cab TRD 4.7
    If it starts ok when you turn the key to "Start" but stops as soon as you return the key to "On" I would suspect the ignition switch.
