Starts then dies
Discussion in '2nd Gen Tundras (2007-2013)' started by Kyro, Mar 14, 2022.
  1. Mar 14, 2022 at 5:41 PM
    Kyro
    Kyro [OP] New Member
    09 Tundra Limited
    My 2009 Tundra 5.7 L. (246,000km) is having starting issues. I found a couple old posts but nothing very recent.
    It started last fall. I changed engine oil. Started truck after I was done and it ran for bout 10 seconds and shut off. Turned key again and it turned over and over and over but wouldnt start one bit. Left it for 10 minutes and then it started fine. Was good for one more month no issues then did it again. I replaced the battery because it was 6 years old and didnt do well on load test. Another month passed and it did it again. I read some posts suggesting it may be the fuel pump relay. Replaced that and a few weeks later it did it again. Its becoming more frequent now. Did it last week and today when it did it it would run for 3 seconds and shut off. Run for three seconds and shut off. I dont believe its a fuel issue cause it turns over with not even a sputter and I cracked the fuel line at manifold and fuel came out. After sitting a few minutes it starts up no problem like nothing ever happened.
    Its not throwing any check engine codes and the immobilizer light is not on like its a key problem. Any help appreciated! I have a video but not sure how to post it on here. Thanks
  2. Mar 14, 2022 at 6:06 PM
    2mchfun
    Clean mass airflow sensor? Check airbox for blockage? Maybe running out of air. Pull of intake tube and unplug mass airflow and try to start. You can have a helper spray some fuel in the intake with a spray bottle and see if it will keep running too. Just cuz fuel is at the rail doesn't mean injectors are not clogged or malfunctioning due to rodent damage to wiring.
  3. Mar 14, 2022 at 8:04 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Tried a different key? Maybe the security chip is wigging out intermittently.?
    Filthyphil likes this.
  4. Mar 14, 2022 at 8:11 PM
    Kyro
    09 Tundra Limited
    I cleaned MAF sensor a couple weeks ago. No blockages in airbox. Ill look around for rodent Damage.
    2mchfun likes this.
  5. Mar 14, 2022 at 8:13 PM
    Kyro
    09 Tundra Limited
    Well I was wondering that. Anyone know if your chip is starting to fail will the red antitheft light still stay off?
  6. Mar 15, 2022 at 6:36 AM
    COTundie
    Trey
    Pretty things
    I believe that IS a thing.
    My red antitheft light does turn off after the engine is started. Let me know if you need the exact point where it turns off.
  7. Mar 15, 2022 at 8:30 AM
    2mchfun
    The more I think on it, I think it is running out of fuel. Considering it was progressive and the age/mileage, I think the fuel supply screen/pump is clogged/weak, simply not enough supply to meet the demand.
  8. Mar 15, 2022 at 8:45 AM
    Kyro
    09 Tundra Limited
    But its not acting like its sputtering and slowly dies. It is a dead stop. I pulled the fuel pump relay and started it trying to re enact the problem and it ran for several seconds then slowly sputtered and died. I can hear the pump running when I had my son turn the key over as well.
  9. Mar 15, 2022 at 9:40 AM
    2mchfun
    Any recent mods?
  10. Mar 15, 2022 at 9:41 AM
    2mchfun
    If you have a remote start or hyperchip try disconnecting them to eliminate them.
  11. Mar 15, 2022 at 1:58 PM
    Kyro
    09 Tundra Limited
    No mods and no remote start
  12. Mar 16, 2022 at 8:14 AM
    1awrencee
    1awrencee New Member
    Lawrence
    2007 Gold Toyota Tundra
    I'm curious, but I wonder if it either the purge valve solenoid or the charcoal canister is bad. not implying that you might overfill your gas but a lot of people tend to squeeze a dollar or more into the tank and what happens is fuel gets into the canister and purge valve. only vapor are suppose to be in those not fuel. It doesnt hurt to try swapping the purge valve from autozone and see if that works. a little over a hundred dollars but it worth a shot. very easy change. and if it is it, the auto part has lifetime warranty, and if not well you can return it.
  13. Mar 16, 2022 at 9:18 AM
    Kyro
    09 Tundra Limited
    Ok. Wouldnt something like that throw a check engine code?
  14. Mar 16, 2022 at 9:43 AM
    1awrencee
    Lawrence
    majority of time it does, p0445 for loose gas cap, but when people check their cap its not the issue. so people get lost on what to do. i kept digging and found someone told me to change the solenoid. You might be right that i could be leading you off to something else, but its a cheap part until you get somewhere even more expensive, the fuel module system, the fuel pump. im not saying the fuel pump is bad, but the electrical side or wiring could be bad... something is cutting off your fuel not sure what it could be. check your battery terminals too while you are there clean it with some scotchbrite and maybe. sometimes it better to get a professional to diagnose the issue and then change the part yourself.
  15. Mar 16, 2022 at 9:49 AM
    Fiesta346
    Fiesta346 New Member
    PA
    2013 Rock Warrior
    Had a similar issue thought it was my battery, keys/ fob, and/or auto start. Issue ended up being the ignition fuse.
    2mchfun likes this.
  16. Mar 16, 2022 at 10:15 AM
    Kyro
    09 Tundra Limited
    Interesting. I have a video I would like to post. Is there an easy way to do it off my phone? I tried doing it and it gave me this message…..
    The following error occurred:
    The uploaded file does not have an allowed extension
  17. Mar 16, 2022 at 11:14 AM
    1awrencee
    Lawrence
    i think the best way would upload on YouTube and post link if not, on the forum you can upload from desktop.
  18. Mar 16, 2022 at 11:33 AM
    Kyro
    09 Tundra Limited
    Ok thanks
  19. Mar 16, 2022 at 11:53 AM
    GNTundra
    Gino
    2013 White
    Crankshaft sensor
  20. Mar 16, 2022 at 3:04 PM
    Kyro
    09 Tundra Limited
    Think so?
  21. Sep 17, 2022 at 9:35 AM
    CharlestonJoe
    CharlestonJoe New Member
    Joe
    Charleston,SC
    2020 White Tundra SR5 5.7 4x4
    TRD intake, Tow Mirrors, Under seat storage, Built in bed storage, Borla exhaust, 3” Icon lift, BFG’s, Method wheels, 1794 grille, Prinsu Roof Rack,
    Whatever happened with this? I’m checking for a friend with an 08, 5.7 his will start, then die, start again die….once it does this he waits 10-15 minutes, it starts up and away he goes just fine. This does not happen every time, just random, he can be out and about, stop at a store then go to leave and ….she dies. Or can be first thing in the morning on a cold engine, so its not temperature related.
  22. Sep 17, 2022 at 10:48 AM
    Kyro
    09 Tundra Limited
    ToyStory291 and Filthyphil like this.
  23. Sep 18, 2022 at 4:42 AM
    CharlestonJoe
    Joe
    Charleston,SC
    Thanks Kyro, the key thing is interesting…
  24. Mar 25, 2023 at 5:15 PM
    ToyStory291
    ToyStory291 New Member
    2007 Tundra SR5
    Stock
    Wouldn't that throw a code and light up the check engine light?
    GNTundra[QUOTED] likes this.
  25. Mar 25, 2023 at 9:20 PM
    GNTundra
    Gino
    2013 White
    Not necessarily, especially if its glitchy. Ive seen a car idle for hours while being diagnosed with no engine code. Then boom it died and the diagnostic machine caught it. Engine code never popped up. New crankshaft sensor and fixed.
    :nuclear:
