Starts and then shuts off
Discussion in '2nd Gen Tundras (2007-2013)' started by Jhiginson, Jun 1, 2022.
  1. Jun 1, 2022 at 1:37 PM
    Jhiginson
    Jhiginson [OP] New Member
    I have a 2012 Tundra with the 5.7 in it. Fuel pump went bad so I replaced it, now the truck gets fuel again.
    Only thing is, now it starts, runs for about 4 seconds and shuts off. If I try to restart it again, it will just crank over. If I let it sit for a few minutes, it will run for the 4 seconds, shut off and so on and so forth.
    Thinking the fuel pump control module behind the tank could be the issue? If there a way to check that without spending another $400 on a part I might not need?
  2. Jun 1, 2022 at 1:59 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome for your first post. Hope you can resolve the fuel issue.
  3. Jun 1, 2022 at 3:39 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Welcome
    How's the battery?? Battery dying will make the truck do weird things.. Have you tried giving it gas until it idles correctly?
  4. Jun 1, 2022 at 3:43 PM
    Jhiginson
    Thanks for the welcome!
    Battery is brand new, checked all the fuses and relays and they seem to be working fine. Noticed the longer I let it sit without starting, the better it starts up.
    I tried to pump the accelerator while it was running and it would shoot up in rpm's as it normally should, then die right back out.
    Could air in the fuel lines be an issue as well for this?
  5. Jun 1, 2022 at 3:53 PM
    Alternator makes these trucks do weird things too. Have you tested it?
  6. Jun 1, 2022 at 5:18 PM
    Jhiginson
    Alternator is good too, everything not fuel related is working as it should be
    Just checked a few more things, great fuel pressure, new pump works awesome, but then starts up, runs and dies 5 seconds afterwards.
    Maybe its a line leaking somewhere? Although I smell no gas coming out
  7. Jun 1, 2022 at 9:37 PM
    blackdemon_tt
    Maybe try keeping an idle for about 30 minutes?? I've had some issues sort of similar... I've sat and watched the idle as soon as it would drop below 500RPM I would give it gas to 1.5 to 2RPM for a few seconds and slowly lay off the gas... Maybe a learning curve for the ECU to learn....
    I know this may be a stretch, but is there fuel in the tank?? More than a 1/4 tank. My 07 gauge is starting to stick again.. I got stranded with a 1/4 tank of gas a couple days ago, but I was empty 1 gal jerry can and a mile huff got me moving.. Would also start for a few seconds then die, or I would put it in gear and would die.
  8. Jun 1, 2022 at 10:31 PM
    Jhiginson
    Thats the thing, I cant keep it idling, it wants to shut down right after it hits the idling rpm's. I try to give it gas to ramp the rpm's up but there is no response. And theres half a tank in it, I removed the gas, cleaned the tank and replaced with new gas and still having the same issue. Tried putting it into gear and it had he same response; stalled out with no success.
    I keep on tinkering with it, could it be a problem with the Mass Air Flow Sensor going bad/being dirty and not getting the correct ratio? I ran an OBD2 check and no codes popped up.
    Going to try and clean the MAFS in the morning and see if it makes a difference
    D4x4TRD and 5N0W808 like this.
  9. Jun 2, 2022 at 4:56 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    A few weeks back someone had very similar issues. Had replaced the fuel pump truck still wouldn’t run. I believe he ended up replacing the fuel pump ecu on the back frame rail and that fixed it.
    It almost sounds like yours is delivering enough fuel for the cold start and then it quits. Reasons why it only runs a few seconds
  10. Jun 2, 2022 at 5:11 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    What are the last two mechanical things you did to the truck?
    Do you have an aftermarket anti-theft system?
  11. Jun 2, 2022 at 7:00 AM
    Jhiginson
    Im about to go and buy a new pump ecu because I think thats the root issue. Just cleaned the MAF sensor with no luck, and I dont want to burn the new pump out. Is there a way to bypass the fuel pump ecu to check if thats it?
    Last two mechanical things were the water pump and oil changes, never had any issues until now. Water pump was 2 years ago. And theres no after market anti theft installed
  12. Jun 2, 2022 at 7:16 AM
    Kur
    Kur New Member
    Mesa, AZ
    08, 5.7, Double Cab Tundra, White
    My 08 did something very similar to this one in a while. I figured out it only happened when i had the key in the ignition for an extended period of time (several minutes) before trying to start the engine.
    Filthyphil likes this.
  13. Jun 2, 2022 at 8:28 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Battery in the FOB going bad and therefore not able to properly complete the "handshake" with the truck's anti-theft system?
  14. Jun 7, 2022 at 9:25 PM
    Kyro
    Kyro New Member
    09 Tundra Limited
    Do you mean like leaving key in ignition but in off position for long periods of time? My 09 has been doing the same thing as Jhiginson every so often since the fall and I leave my key in ignition all the time at home. I wonder??
  15. Jun 8, 2022 at 5:27 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Sorry just saw this, give me a few minutes and I will see if there is a way to “jump” the fuel pump ecu briefly to test and see if the truck runs correctly
  16. Jun 8, 2022 at 8:34 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    + me too. Handful of times. Just got used to not leaving the key in the ignition (off)
  17. Jun 9, 2022 at 9:46 AM
    Kur
    Kur New Member
    Mesa, AZ
    Yes. That is what I mean. This issue only ever happened when I stopped at a fast food place, then parked to eat my food. I would turn the engine off, leave the key in the ignition and eat my food and maybe watch some YouTube. When I went to start the engine again, it would fire up, run for a second, then die. That would happen over and over (one time it never started but just kept cranking until I turned the key back) until I pulled the key out of the ignition, locked the truck, unlocked it, got back in, and tried to start it again. I also called my brother in the meantime, so I don't know if there is a certain amount of time that has to pass or what..
    I think it has something to do with the little security chip inside the key. Might be a security feature that prevents theft of your truck if you accidentally leave your keys in the ignition or something.. I'm not sure.
    But ever since I stopped leaving my key in the ignition, I haven't had this issue.
  18. Jun 9, 2022 at 9:49 PM
    Kyro
    Kyro New Member
    09 Tundra Limited
    Ok thanks. Im going to start taking key out alll the time now and see if it goes away.
  19. Jun 10, 2022 at 11:21 AM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    Any luck?
  20. Jun 10, 2022 at 4:20 PM
    Kyro
    Kyro New Member
    09 Tundra Limited
    Im gonna give it some time. Its been 1 day.
  21. Jul 9, 2022 at 9:15 AM
    Kyro
    Kyro New Member
    09 Tundra Limited
    So its been a month since I started taking the key out. Its only acted up once but only because I forgot and left the key in it one time. I did as Kur said and pulled the key out of the ignition, locked the truck, unlocked it,got back in, and tried to start it again and it fired right away. What a simple thing that could have ended up costing in unnecessary repairs and dealership visits. I hope this helps other people that are having similar issues. I will report back if it starts acting up again. Thanks Kur for the suggestion!
    Filthyphil and Jeff_5_7 like this.
  22. Jul 9, 2022 at 9:21 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Reset the security ecu and it’s recognition of the key.
    Nice to know that fixed it. Makes you think there is a timer in the truck to see and verify the key after putting it in the ignition.
  23. Jul 9, 2022 at 12:27 PM
    Kyro
    Kyro New Member
    09 Tundra Limited
    Ya something like that
  24. Jul 9, 2024 at 2:58 PM
    Absolutegtr
    Absolutegtr New Member
    Any update to your situation on this? (The leaving the key in (off position) and the truck not starting)
    I have a 2019 platinum. And it’s only happened twice in the last 3 weeks. The only commonality I can see so far (since it only happened twice) is I left the key in the ignition (off position). Once while getting gas and a second time while waiting for my wife for 5 minutes while she was getting some groceries)
  25. Jul 9, 2024 at 3:17 PM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Something similar with my 07. You start the truck, it starts right up, rpm's come up to 1500-2000 like it should and then it immediately dies. You try again, same thing happens. It's like someone is turning off the key. You wait 5 minutes it starts right up and you are good to go. Like it never happened. At first I thought it was the FP but I've had no issues with normal driving. But now I wonder if maybe there is debris in the gas tank that's maybe floating around and clogs the pump. I don't know. The problem happens so infrequently, you could chase after a cure but you don't even know what the problem is. I'm just going to run it until I can really identify the problem and fix it from there.
