Starting problem
Discussion in '1st Gen Tundras (2000-2006)' started by Larry6464, Mar 29, 2021.
  1. Mar 29, 2021 at 9:39 AM
    Larry6464
    Larry6464 [OP] New Member
    Larry
    North Carolina
    2008 toyota tundra crew cab
    I have a 2002 Toyota tundra sr5 with the 4.7 v8. When you first turn it over it dont wanna start. And sometimes it turns over for about 10 seconds before it starts. I am thinking plugs and/or coil packs. Anyone have any other ideas?
  2. Mar 29, 2021 at 9:47 AM
    Professional Hand Model
    Hand Protectors
    Whats your maintenance history?
    Miles on truck?
  3. Mar 29, 2021 at 9:51 AM
    Air, spark and fuel. Those three things are necessary for the truck to run. Check your fuel delivery. Fuel filter, fuel pump and fuel injectors. Clean the MAF and the throttle body and make sure the air filter is in good shape. And proceed with your spark plugs and coil pack inspection. Start with the easy, free stuff, like cleaning and inspecting before moving on to spending money on new parts.
    Casper421 likes this.
  4. Mar 29, 2021 at 3:39 PM
    Larry6464
    Larry
    North Carolina
    186000 miles. But I have only owned the truck for approximately 7000 miles. Thanks KnaBores. I will check it out.
  5. Mar 29, 2021 at 3:41 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Mine was kind of doing something similar. Cleaned the throttle body and it cleared it right up.
  6. Mar 29, 2021 at 4:55 PM
    Larry6464
    Larry
    North Carolina
    Thanks southpaw
  7. Mar 29, 2021 at 5:07 PM
    Hand Protectors
    Pull plugs and take pics of plugs and coils.
  8. Mar 29, 2021 at 5:17 PM
    SouthPaw
    2000 Limited 4x4 AC
    If you pull the plugs and you don’t know the last time they were changed, replace them, they are cheap enough.
    WILLINH and BubbaW like this.
  9. Mar 30, 2021 at 5:17 AM
    Larry6464
    Larry
    North Carolina
    Yes for about $150 I can replace plugs and coil packs.
    WILLINH likes this.
  10. Mar 30, 2021 at 5:59 AM
    Seems really cheap for coils, what brand are they?
    MEWaters likes this.
  11. Mar 30, 2021 at 8:50 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    really cheap since most on here speak of Denso 50ish a pop....$400 fairly normal
  12. Mar 30, 2021 at 10:58 AM
    Larry6464
    Larry
    North Carolina
    They are cheap but I only drive my truck about 3500 miles a year
  13. Mar 30, 2021 at 11:14 AM
    Might not make it that far if those coils are glitchy. Report back about their performance and good luck sir.
  14. Mar 30, 2021 at 1:32 PM
    Hand Protectors
    I’ll use a phrase here I use a lot but not because its your name although it works about those $150 coils.... Scary Larry!:rofl:
    I only say this from reading the Denso 1303 Coil Pack reviews on a site. Mostly they were Land Cruiser Guys with the same 4.7L engine we have except they got theirs in 1997 so we can see how time effects the same engine.
    Mostly, they needed new coils and bought 8 chinesiums for about the same price you mention of $150. They performed poorly and often failed. Go read for yourself as I have nothing to gain here. The other option is to spend $180 a pop at Toy stealership for the same Spec’d Denso for about $55.
  15. Mar 30, 2021 at 4:31 PM
    Larry6464
    Larry
    North Carolina
    Ok thanks guys for the advice. I am sure your right. I will just wait till I have the money for them.
  16. Mar 30, 2021 at 4:52 PM
    Nick T
    Nick T New Member
    Nick
  17. Mar 30, 2021 at 4:55 PM
    Hand Protectors
  18. Mar 30, 2021 at 5:25 PM
    Nick T
    Nick T New Member
    Nick
    I have them on both my tundra and lx470, been a year on lx470 and 6 months on tundra, still working fine.
  19. Mar 30, 2021 at 5:27 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    buy once, cry once
  20. Mar 30, 2021 at 5:44 PM
    Hand Protectors
    That Made in Japan gives confidence. Glad the are working for you. A few LC Guys reviews seemed solid. One guy did a multiple over time come back review which I like. Think he had 2 years on them.
