Starting issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by ddub74, Mar 16, 2024.
  1. Mar 16, 2024 at 6:59 PM
    ddub74
    ddub74 [OP] New Member
    2017 Toyota Tundra won’t start at times. Replaced the battery and still same issue. So I figured it’s the starter. Bought a starter from the dealership and replaced it and still same issue. Had both starters checked and both came back good. So when I have the issue of not starting I turn the key and no sound. Everything still comes on, radio and lights on dash. So when it don’t start I go under the truck and tap the starter and it turns over and start. Need help with this issue!
  2. Mar 16, 2024 at 7:09 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Check your battery cables . I had that happen before on an old Ford and it turned out to be the negative battery cable . It was corroded .
  3. Mar 17, 2024 at 3:06 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Well if it starts by tapping probably the starter or a loose connection on the start. Do a wire wiggle test to eliminate the wire possibility.
