Starting Issues 08 Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by Biggernumber27, Apr 18, 2021.
  1. Apr 18, 2021 at 5:33 PM
    Biggernumber27
    Biggernumber27 [OP] New Member
    Johnny
    Sometimes when my crank my Tundra the starter cranks or tries to engage and after trying to crank it multiple times when it finally turns over it tries to crank for about 15 seconds before it finally starts. Then I will not have issues for a couple of days then it does it again randomly. Any ideas?
  2. Apr 18, 2021 at 6:25 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
  3. Apr 18, 2021 at 6:45 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Battery, get it tested, sometimes big drops in temperature will cause battery issues..
    Rex Kramer likes this.
  4. Apr 18, 2021 at 7:06 PM
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    It could be the starter solenoid getting stuck or the ignition lock cylinder binding.
  5. Apr 18, 2021 at 7:29 PM
    blackdemon_tt
    Sticking starter will not crank, it will click and nothing will happen... you can ask me how I know.
  6. Apr 19, 2021 at 4:01 AM
    Biggernumber27
    Johnny
    Battery is brand new. 3 weeks old
  7. Apr 19, 2021 at 4:02 AM
    Biggernumber27
    Johnny
    But why does it turn over for like 15 sec when tge starter acts up?
  8. Apr 19, 2021 at 4:50 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I would still test it, as well as the fuel pump.
  9. Apr 19, 2021 at 8:24 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Crank-to-start function. ECU is timing out the starter run.
    Once you've turned the key to START, the start cycle is no longer under your control. ECU sets the proper starting air/fuel ratio (or not), ignition timing, crank time, etc. Try this test: Turn the key to START position and RELEASE. If the engine doesn't start, the starter should continue running until the ECU times out the starter run. Maybe the design start cycle is 15? seconds, which is plenty. Mine always starts in the first second so I haven't had the opportunity to observe.
    As to the reason your truck isn't starting, I would suspect fuel, air, or spark in insufficient quantity.
    @Ruggybuggy.
    Ruggybuggy likes this.
  10. Apr 19, 2021 at 8:32 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If it was in the shop Techstream would be coming out and checking to trouble codes. It can also be used to active test starter circuit.
    Do the obvious stuff first like checking for a good connection at the battery. Check the connections at the starter and check your grounds. After that Techstream should be used to diag.
    JohnLakeman[QUOTED] likes this.
  11. Apr 19, 2021 at 9:06 AM
    JohnLakeman
    If your truck is equipped with an Immobilizer, there is a chip in the key that is read by the ignition switch. If that chip goes bad, your truck will not start, and/or will not run. Given the intermittent nature of your problem, that chip may be on the way out. You might try using your spare key to confirm the key chip isn't the issue.
  12. Apr 19, 2021 at 9:09 AM
    blackdemon_tt
    My SC400 battery fried a cell and required a replacement battery at 3 weeks, only turned it on twice back then. My Tundra has killed them all at some points, and yes even less than 3 weeks... Obviously batteries sit in some warehouse and shelf for about 1 year to a year and a half before they get purchased...
  13. Apr 19, 2021 at 7:54 PM
    Dmas
    Dmas New Member
    FTL, FL
    You did not say how many miles you currently have on that truck, it could be just the starter about to go out.
