Starting Issue
Discussion in '1st Gen Tundras (2000-2006)' started by Quansoo, Dec 19, 2023.
  1. Dec 19, 2023 at 6:04 AM
    Quansoo
    Quansoo [OP] New Member
    paul
    2006 tundra extra cab
    My first posting! I have a 2006 Tundra Double Cab Limited with Leather, (only 42,000 miles), and it seems about every week the engine won't turn over. I hear a noise which would sound like a low battery. I had battery tested at NAPA and they said it is fine. All I do each time is jump start it, it starts right up. I do not think I am leaving anything on, but maybe a new parasitic drag is happening? Napa did use an expensive tester so I ruled out the battery. If it starts with a jump easily, does that rule out the starter, ignition switch, and any relays? I did not look at far end of battery cables yet, but cable side that connects to battery looks good. Truck has always been garaged.
  2. Dec 19, 2023 at 7:02 AM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    If it fires off with a jump, that means the battery is not holding a charge or is being drained. Parasitic draws can be found with a volt meter. If you are certain that the battery is good, then you need to test for a draw and begin to isolate circuits to discover where the draw is coming from.
  3. Dec 19, 2023 at 7:03 AM
    shifty` Animals and insects don't do drugs
    Huh. I know this will sound crazy, but I remember a couple of DC owners now who found the wire to their tweeter at their sail panel was smashed and arc'ing, and that was causing parasitic drain.
    Do you know how to test for parasitic drain? I can post a video. Alternately, try removing the RADIO (I think?) fuse in the dash before letting it sit. See if it cranks normal. Or test the voltage BEFORE you start.
  4. Dec 19, 2023 at 9:54 AM
    Quansoo
    paul
    Please post a video on how to check parasitic draw. Thx
  5. Dec 19, 2023 at 10:02 AM
  6. Dec 19, 2023 at 12:58 PM
    flyfisher
    flyfisher Member
    David
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
