Starting an Audio Build this weekend
Discussion in 'Audio & Video' started by Blankcheese, Aug 11, 2016.
  1. Aug 11, 2016 at 4:40 PM
    Blankcheese
    Blankcheese [OP] New Member
    Johnny
    '16 SR5 DC 4WD
    Sold my stock Entune and bought a Kenwood Excelon. Dual Rockford Punch amps for the Kickers going in the doors and 10" Sub under the rest seat. Lots of harnesses and steering wheel control adapters coming from Crutchfield. Also building my own sub enclosure for the first time. I'm going to take pics along the way and add it to a build thread. Looking forward to the challenge and hoping I can get it all put back together!
    BlueBottle and RussellVaughan like this.
  2. Aug 11, 2016 at 9:00 PM
    :popcorn:
  3. Aug 13, 2016 at 4:00 AM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    This isn't everything, need to unbox and inventory and see what's missing. I have a Lowes 10 minutes away I think they're going to see a lot of me this weekend. Head unit and harnesses/steering wheel controls adapters from Crutchfield. I will be blowing up their 7-day per week technical support.
    aperezsh and MotoTundra like this.
  4. Aug 13, 2016 at 5:49 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Good luck!
  5. Aug 13, 2016 at 8:58 AM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    image.jpg Detailed list of components later, a few progress pics now...
    SouthBoundSteve and aperezsh like this.
  6. Aug 13, 2016 at 9:01 AM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    image.jpg I must be nucking futz!
  7. Aug 13, 2016 at 9:14 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    My wife thought I was crazy when I had everything including the dash pulled out of my truck at 5k miles. What model excelon did you get? I bought one without nav since I always use my phone, but it's been an excellent stereo
  8. Aug 13, 2016 at 10:46 AM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    Me too. I don't need navigation. I'm a little worried because this is the first audio build I've ever done and there are so many connectors and adapters etc..
    Kenwood Excelon DDX6902S
    TruckyTruck likes this.
  9. Aug 13, 2016 at 11:39 AM
    TruckyTruck
    Gary
    Don't be! It's just like doing a puzzle. Just take your time, splice everything very solid and make it clean. I drove around for a week with only the drivers seat because I didn't get finished in one weekend. But I was using raam mat to sound deaden everything. If you take your time and ground everything well, you won't have to go back and change things. My biggest problem was the little panel pieces got smashed when I was reinstalling the panels. But they are cheap and easy to get from the dealer or auto part store.
  10. Aug 13, 2016 at 11:42 AM
    TruckyTruck
    Gary
    Bob likes this.
  11. Aug 13, 2016 at 3:06 PM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    Thanks Trucky I bookmarked that site.
    I'm having trouble right now crimping the 4GA wire to the lug for the positive battery terminal. I'm thinking I might have to solder that one.
    The other two "tricky" pieces are the wires running from the old factory head unit to the amp I removed from under the passenger front seat. Do I need any of those if I'm running to two new amps?
    The other puzzler is getting new speaker wires to the doors and where/how to mount the crossovers in the doors.
  12. Aug 13, 2016 at 3:13 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Right on man way to get after it. Looking forward to the rest of this build.
    Blankcheese[OP] likes this.
  13. Aug 13, 2016 at 3:41 PM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    image.jpg image.jpg Used a roll of Peel & Seal on the rear cab wall
  14. Aug 13, 2016 at 5:38 PM
    TruckyTruck
    Gary
    Did you buy a wiring kit with adapters for the new radio to old wiring? I actually rewired the entire truck with 16 guage wiring for the speakers, 0 guage from the battery to the splitter block and 4 guage from the splitter to my two amps. So I didn't use any of the tiny wiring from the factory. You could always run new wiring for your amps. It might take the headache out off figuring out the factory wiring.
  15. Aug 13, 2016 at 5:52 PM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    Yeah I bought 4ga from battery to amps. And speaker wire and adapters. So I guess besides getting power to the new head unit I'll be replacing everything else
  16. Aug 13, 2016 at 6:35 PM
    TruckyTruck
    Gary
    If you can, and are happy with the stock wiring in the doors, it's easiest to keep the door wiring. I replaced mine, but it was very difficult running new wiring thru the wiring openings leading into the door. In the back doors, maybe the front too, I just can't remember because it's been a couple years, there is a plastic block that I had to drill an existing hole a little wider to fit my new wiring thru. In the front, I had to use a hanger with wire taped on the end to fish thru the rubber canal for all the wiring. Took a little time for both, but came out nice.
    Here is a thread on the subject. Not mine, but it's useful if you run new wire.
    http://www.tundratalk.net/forums/tu...g-speaker-wire-crewmax-rear-doors.html#/enter
    Just be careful with all the clips, they break easily.
  17. Aug 14, 2016 at 1:03 AM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    Yeah I broke one of the front mounting points of the center console outer shell. I think it will all go back together ok.
    Thank you for mentioning that plastic block on the back doors I wasn't ready for that. So I guess I could keep the section of speaker wire from the door speakers to the door jambs and intercept them from that point and splice new sections to the 4-channel amp?
  18. Aug 14, 2016 at 1:09 AM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    Great thread with at close-up pic that's really helpful thanks Trucky!
    TruckyTruck[QUOTED] likes this.
  19. Aug 14, 2016 at 6:06 AM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    image.jpg Here's the footprint for the under seat sub, Kicker VR 10". Box will finish at about 1 cubic foot of volume.
    The caster is what I used to smooth out the sound deadening material, worked great!
    MotoTundra and TruckyTruck like this.
  20. Aug 14, 2016 at 11:18 AM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    image.jpg Halfway through the sub box build I figured out that I didn't account for the 3/4" thickness of the MDF. So, back to Lowes for more lumber and increased the footprint to 28"x22" with a notch for the seat belt mechanism in the rear. Notched the bottom of the front face to accommodate the transmission tunnel. These new dimensions should give me about 1 cu foot of volume.
    TruckyTruck and TheBeast like this.
  21. Aug 14, 2016 at 3:36 PM
    TruckyTruck
    Gary
    I ended up stuffing some foam behind the back wall and plastic... No rattles. Just fyi!
  22. Aug 16, 2016 at 2:50 PM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    image.jpg *********.com had a great video for 2014-2016 front door panel removal. The window switch connector would have been tricky without their video.
  23. Aug 16, 2016 at 3:08 PM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    Scosche SAT69 6.5" speaker adapters
    MotoTundra likes this.
  24. Aug 16, 2016 at 3:11 PM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    Pink/grey, purple/grey front left channel speaker wires. The second photo is where I'm going to intercept those wires and bring them to the Rockford Punch 500 amp under the passenger seat.
  25. Aug 16, 2016 at 3:24 PM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    image.jpg image.jpg The front right side is green/grey and blue/grey
  26. Aug 16, 2016 at 3:39 PM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    image.jpg Right rear door wiring is white/grey, red/grey
  27. Aug 16, 2016 at 5:16 PM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    image.jpg Driver rear door is red white like the passenger rear side, I though they'd be different
    aperezsh likes this.
  28. Aug 18, 2016 at 6:00 PM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    Used some leftover Peel & Seal to line the inside of my subwoofer box:
  29. Aug 19, 2016 at 4:42 PM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    image.jpg Wiring the 10" Kicker Comp RT for 1 ohm operation
    TruckyTruck and MotoTundra like this.
  30. Aug 19, 2016 at 5:30 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Coming along nicely!
