Startibilty Issues- Flex Fuel - Reading 85% Ethanol
Discussion in '2nd Gen Tundras (2007-2013)' started by Jeffro22, Dec 1, 2022.
  1. Dec 1, 2022 at 10:04 AM
    Jeffro22
    Jeffro22 [OP] New Member
    2013 platinum crewmax 4x4
    Truck started having really bad starting issues over the past few weeks. ALmost happening every morning. Takes 3 full key cycles/cranks before it actually starts. Runs rough for a few seconds and blows some smoke and then seems normal. Starts fine the rest of the day
    Checked the Ethanol reading with my scanner and its reading 85.1%
    It did this last year, but maybe only 2-3 times total.
    What's the latest on the fix? Is the dealer flash still just a temporary fix?
    Should I look at swapping fuel pump and possibly doing the mod to bypass the flexfuel/low pressure return at the switch valve?
  2. Dec 4, 2022 at 8:23 PM
    BozickA88
    BozickA88 New Member
    2022 Tundra
    Most recent fix is fuel pump and update. T-SB-0166-19
    B.Ross likes this.
  3. Dec 6, 2022 at 6:46 PM
    Jeffro22
    Thanks. Guess I Will plan to take to dealer. Will let you know how it goes
  4. Dec 6, 2022 at 7:36 PM
    texmln
    texmln New Member
    Just buy the $30 software on Ebay and reset it yourself. Every time I had it to the dealer for the fix the problem came back. No surprise since they jacked me for $150 each time. Since I reset it myself it's never happened again but I still have the software if I ever need it.
    Jeffro22[OP] and Skew12 like this.
  5. Dec 7, 2022 at 3:56 AM
    Jeffro22
    Do you have any more info on this or a link? Would like to give it a try
  6. Dec 8, 2022 at 8:22 AM
    Jeffro22
    Thanks ! ordered the techstream- Will update once I receive it
  7. Dec 13, 2022 at 2:54 PM
    Nufaze
    Nufaze New Member
    Pablo
    2013 Tundra Crewmax 4x4
    6" lift, 35's, CAI, Flowmaster super 40 exhaust
    What is the software needed?
  8. Dec 22, 2022 at 11:01 AM
    Jeffro22
    You can find on ebay or Amazon. Tech Stream - search
    OBD2 Diagnostic Cable for Toyota Lexus Scion or
    https://www.ebay.com/itm/403927130010
    thanks, took me a little while to get my laptop situation figured out. Ended up using a newer laptop with virtual box. Got my ethanol reset to 0%. Will continue to monitor but truck starts and idles a lot smoother. Hate I waited so long
    Skew12 and Nufaze[QUOTED] like this.
  9. Dec 25, 2022 at 5:31 PM
    Jeffro22
    So far so good. Put about 700 miles on it since reset
    just checked and it’s reading 1.2%ethanol.
    Truck is starting perfect and seems to be running smoother
  10. Dec 25, 2022 at 6:55 PM
    texmln
    texmln New Member
    Glad it worked out for you.
    Jeffro22[OP] likes this.
  11. Dec 26, 2022 at 2:46 PM
    Jeffro22
    Yeah, Thanks for turning me onto it.
    Used it today to program my spare key I bought off Amazon
  12. Dec 29, 2022 at 2:46 PM
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    Sorry you're having this problem, but this is why I would never own a Flex Fuel vehicle of any kind.
    Skew12 likes this.
  13. Dec 30, 2022 at 10:16 AM
    Jeffro22
    Yeah. Didn’t research it it before I bought. Would definitely prefer to not have the ff but that really limits what you can find
    now that I have the alcohol density reset truck is running great. Especially considering it has 282k miles
    just wish I would have looked into re-setting it myself sooner. Was easy enough once I got software setup
    Skew12 and CTB Mike[QUOTED] like this.
  14. Jan 16, 2023 at 9:00 AM
    Jeffro22
    just an update. Truck has been running great and no starting issues at all. I have been driving a bunch and have racked up about 5k miles since reset. Unfortunately my ethanol reading is creeping back up. I just checked and it was at 48% before a fill up and after fill up was reading between 55-60%
    Will plan to reset again and monitor. Not sure if I will eventually need to take it in to dealer and get re-flash of the computer also
    swampmusic and Skew12 like this.
  15. Mar 1, 2023 at 9:05 AM
    Jeffro22
    I have had to reset my density 3 times now since i first did it back in December. I have been driving a lot, but looks like it doesn't take very long to creep back up
    I checked this am it was at 54% . I can tell by the way the truck runs/sounds if the density is reading high. IT runs so much better when its at zero (or under 15%)
    Wish there was a permanent fix, but I guess i'll just plan to reset every month or so
  16. Mar 24, 2023 at 9:50 AM
    swampmusic
    swampmusic New Member
    Jeffro22 I’m having the same issue on my 2016 for the second time. Had the TSB done in 21 and now it’s back. No permanent fix that I can find. I ordered the Amazon cable and software to reset the density myself and cannot get it installed correct. Anyway you may be able to help?
  17. Mar 25, 2023 at 5:55 AM
    Jeffro22
    I couldn’t get the software that I received with the cable to install either
    go search on Google Techstream in 5 minutes find and follow the instructions on IH8MUD think YouTube has some videos also
    swampmusic[QUOTED] likes this.
  18. Mar 25, 2023 at 7:41 AM
    swampmusic
    I tried that as well and can’t get the virtual box to work, it constantly says “aborted”. I am going to try uninstalling everything and starting over. After that I guess I’ll drop the $400 on a vf tuner. Thanks for the feedback.
  19. May 10, 2023 at 6:40 AM
    Jeffro22
    reset mine again. 5/10/23 @289,877.. ethanol reading was up to 68.2%
    doesn't seem to be lasting long between resets. going to try to start logging readings, but guessing its only making it a couple thousand miles before reading is high
  20. May 10, 2023 at 11:25 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
  21. May 11, 2023 at 6:26 AM
    Jeffro22
  22. May 12, 2023 at 2:36 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I guess that's the woes of flex fuel owners. I have yet to experience any issues yet, but assume eventually I will. Definitely one thing I didn't do my research on when upgrading my gen 1 to a gen 2. Other than this issue I know I'll still get 300k out of this rig before I pass it along though. I have that much faith and past experience in the Toyota brand. They just plain own my loyalty.
    AZBoatHauler likes this.
  23. Jul 3, 2023 at 10:25 AM
    Jeffro22
    Not making it very long before having to reset
    293,128 mileage - fuel density 76.1%
  24. Dec 14, 2023 at 7:20 AM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    So does it help any to once in a while run a full tank of ethanol-free gas through it or to use some kind of fuel additive?
  25. Mar 29, 2024 at 12:20 PM
    pablo89
    pablo89 New Member
    pablo
    Miami
    2018 tundra platnium
    Rollnlock amp steps fuel wheels nitto ridge led lights
    having to reset about every week. and when I read my alcohol level ive been getting 0% not sure if im looking at the correct thing
  26. Mar 29, 2024 at 12:44 PM
    Totmacher
    Daniel
    West TN
    Some
    How high are long term fuel trims?
    On mine, trims and alcohol % readings were both high. There were 2 things i reset and then added 3 gallons fuel per the TSB instructions before starting/driving. No problem since. Took a while for numbers to stop fluctuating though. 3 tanks worth maybe.
  27. Apr 2, 2024 at 7:21 AM
    pablo89
    pablo89 New Member
    pablo
    Miami
    so what did you reset all I reset was the alcohol density. my ft long have ranged between 7%-25% the times ive seen it sometimes less then 7%
  28. Apr 2, 2024 at 7:44 PM
    Totmacher
    Daniel
    West TN
    Some
    I did one called "learning value reset" and another called "fuel density learning value reset". Then added 3 gallons gas. Then started it and went on a long test drive.
    The adding gas is part of the TSB instruction that Toyota would do. I noticed first couple of fuel-ups after resetting the numbers fluctated a little so there must be something about adding gas that triggers the computer to take a reading.
    https://static.nhtsa.gov/odi/tsbs/2019/MC-10170730-9999.pdf
    Basically did steps 7-14 from that TSB except I used the other tool instead of Techstream.
  29. Nov 8, 2024 at 6:22 AM
    WodenTX
    WodenTX New Member
    Duke
    Saint Johns, FL
    2015 Black 1794
    Hi, what other tool instead of techstream did you use?
  30. Nov 8, 2024 at 3:34 PM
    Totmacher
    Daniel
    West TN
    Some
    Launch x431 off scamazon is what I used. It was the one linked in other thread above I think.
    WodenTX[QUOTED] likes this.
