Starter went out, now check engine light
Discussion in '2.5 Gen Tundras (2014-2021)' started by Nygmen124, Nov 8, 2023.
  1. Nov 8, 2023 at 8:29 AM
    Nygmen124
    Nygmen124 [OP] New Member
    Jesus
    KY
    2014 Silver Lifted Crewmax
    6 in lift kit on a 2wd. Done by previous owner. Don't blame me.
    So i have my starter solenoid go out on my truck. I had to bypass the solenoid to start the truck and get it to the shop. The shop was able to replace the starter but the check engine light and traction control off appears on the dash. I am getting 3 codes P0894, P144C and P2714. I am not having an drivability issues. I tried clearing the codes with OBD reader and also disconnecting the battery for 30 minutes. But that did not help. Truck has a brand new battery as well. Any suggestions?
  2. Nov 8, 2023 at 9:45 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    P0894 and P2714 are issues dealing with the transmission. Drain and fill should assist in eliminating the issue, they may or may not come back, so I would do 1 every oil change until you completely change the color of the fluid, if it isn't already looking red.
    P144C you may need to look at your intake tube and ensure all vacuum hoses are pushed in all the way. Either way, here is an old post on your trouble code. Best of luck.
    Got code P144C | Toyota Tundra Forum (tundras.com)
  3. Nov 12, 2023 at 3:25 AM
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    Make sure nothing was left unplugged, or wiring damaged if happed after starter was replaced.
