Starter or Battery?
Discussion in '2nd Gen Tundras (2007-2013)' started by cfe4130, Jun 10, 2020.
  1. Jun 10, 2020 at 12:42 PM
    cfe4130
    cfe4130 [OP] New Member
    I have a 2012 Crewmax 4.6 2wd. I can't get it to start today. A few times there was some repetitive clicking. The clicking also occurred after I disconnected the battery for ten minutes, reconnected it, and try to start it again. Dash lights up and all lights are working. I recently installed AlphaRx headlights. I had an issue the other day leaving the store, but it appeared the battery connection was not tightened enough after the headlight install. The battery is getting 12.12 volts. I did try to jump it off for about 30 minutes with my Taurus; no difference.
    Does this mean that it's the starter?
    Edit: I just noticed that when the key is in the on position, the AC doesn't run. I'm not sure if that is a sign of something.
    3:01PM: I just checked the battery, and it's now at 7.14
  2. Jun 10, 2020 at 1:33 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    12.12v on a standing battery no load it’s not bad
    7.14 will not crank that vehicle
    AC compressor will not work with engine not running easy test use the battery from your Taurus to start the tundra I know it’s not the right one but that will tell you if you have a bad battery or starter cause you know the battery for the Taurus is good
    Once the Tundra starts let it idle for about 15min all accessories off so it can relearn
  3. Jun 10, 2020 at 1:51 PM
    cfe4130
    I just got it tested and the battery is fine. I'm about to re-install it and see if it cranks.
  4. Jun 10, 2020 at 2:13 PM
    cfe4130
    It cranked up right away. There must be something draining the battery. It was 12.53 right before I reinstalled it. I also installed a 9" Android head unit a few days before. Maybe I check the AlphaRx and see if others are having battery issues.
  5. Jun 10, 2020 at 2:17 PM
    Yeah it sounds like something is pulling a draw. I would look at the radio wiring.
  6. Jun 10, 2020 at 3:12 PM
    cfe4130
    The radio is all plug and play. Right now I have the extra headlight wires disconnected.i used a YouTube video to connect the headlight led. Maybe those guys installed them incorrectly.
  7. Jun 10, 2020 at 10:17 PM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    With the truck running put a volt meter across the - and + on the battery see if you have at least 13.5V charge going into the battery. If not boost the engine idle up and see if it will increase to 13.5V
    TheBeast likes this.
  8. Jun 10, 2020 at 10:39 PM
    TheBeast The Beach
    remove alpharex and monitor for couple of days
    YardBird likes this.
  9. Jun 13, 2020 at 2:13 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    after you fully charge the battery with a charger. hook it up and check that is getting charge from the alternator , make sure your connections are clean and tight , if it feels tight but is loose get a terminal shim. if all that checks out . monitor the battery while its off and see if its losing power while every thing is off. if it is losing power hit me up ill help you chase it down.
    p.s post a link to the YouTube video you watched , i want to see what method/pathway they used.
  10. Jun 13, 2020 at 2:44 PM
    stangless40
    stangless40 New Member
    Alberta Canada
    17 Platinum
    lots
    Sometimes its not always the volts, i had 12.7 volts and it didn't start, its the cranking amp you need to start the truck, i tested the battery and i only had 375 cranking amps, for the newer trucks you need 710 cranking amps just to turn the starter to crank it.
  11. Jun 15, 2020 at 6:14 AM
    cfe4130
    The truck has been running fine for the past few days.
    I forgot to mention that I also installed HIDs in the AlphaRx headlights. Because I had ordered a H7 HID kit, the ballast connection did not fit in the stock bulb plug. I had a plug lying around that did fit in the ballast which has two prongs that fit into the stock connection. I used this as a temporary fix until I received the correct connection. The night before the battery issue, I went to aim the headlights and the drivers' side was not working. After messing with the connection, I noticed that the ballast had a burnt/melted spot on it, so I removed it.
    The following day when the truck would not start, I did remove the AlphaRx DRL wires. Those wires along with the HIDs have been disconnected since then, and I have not had any problems.
    This is the video that I used.
    https://www.youtube.com/watch?v=D9uRyyNU_dE&t=169s
    Today, I'll reinstall the DRL wires and check the battery throughout the day.
