Starter madness
Discussion in '1st Gen Tundras (2000-2006)' started by Motosurfsnow, Mar 5, 2022.
  1. Mar 5, 2022 at 7:11 PM
    Motosurfsnow
    Motosurfsnow [OP] New Member
    2005 Double Cab SR5 TRD
    Wow what a quest. So last Saturday did a 20 minute drive. Parked and after only getting one click, sound coming from starter. Since I’ve done.....New starter, new ignition, ignition switch, new battery, new starter relay, checked the Park/Nuetral safety switch.
    pulled new starter, it tested bad, 2nd new starter....tested it before install....even jumpered the switch wire to it while out and it was working good. Have good ground at block and good voltage at starter main post wire. Put the 2nd new one in and again just one click. Not popping any codes besides what I pulled off w intake manifold to get to the starter and the switch wire was working as I said when it was out.
    It sounds like the starter shaft is only popping out partway and maybe hitting something? That’s what it sounds like to me but idk. I looked at a little casing just inside casing where starter goes in and measured to make sure that cleared. Seemed fine. Put a rat Jon the crank and the motor turns over. Totally out of ideas at this point. Thanks for any help.....
  2. Mar 5, 2022 at 7:17 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Lot of electrical work - could the starter be failing to get enough amps?
  3. Mar 5, 2022 at 8:22 PM
    BMET
    BMET New Member
    2018 Tundra Limited
    I would check the cables. Perhaps a bad connection on one of them.
    Just me.
    Aerindel likes this.
  4. Mar 5, 2022 at 10:32 PM
    Aerindel
    Aerindel New Member
    Montana
    Yep. Sounds like battery cables.
    If it's a failure of the starter gear to engage you would hear a 'whirring' sound as the starter spins without engaging the flywheel.
    des2mtn likes this.
  5. Mar 6, 2022 at 9:03 AM
    shifty` Bohannon Bohannon Bohannon Bohannon
    I'm going with cable issue. Either loose ground, corrosion inside the cable, and ... fml, I'm starting to sound like a broken record. Why the hell doesn't anyone ever check the cables first? It's always the easiest solution and solves the problem in like 1/3 of cases with almost no disassembly of the engine.
    Kimosabe, 2002tii and Siebler like this.
