Star problem
Discussion in 'General Tundra Discussion' started by Perron, Nov 11, 2018.
  1. Nov 11, 2018 at 1:11 PM
    Perron
    Perron [OP] New Member
    Hey guys how you doing I'm new here I just have a question for you guys I have a Toyota Tundra 5.7 wont start I just buy the fuel module and the truck start over again.but today they have same problem. Truck won't star again ,
    I appreciate any help thank you.
  2. Nov 11, 2018 at 2:13 PM
    trdprobped17
    trdprobped17 New Member
    How old is the truck? Why do you believe that it has something to do with the fuel system? If you have a history of fuel system problem, then, it could be a faulty sending unit, bad gas, clogged line. I do recommend that you try to determine the source of the problem first, before spending anymore money on parts that may not necessarily be the problem.
    Try taking it to the dealership for a proper diagnostic check. Then, take it from there. Good luck.
    Thegr8punkin likes this.
  3. Nov 11, 2018 at 3:19 PM
    Perron
    Thanks I appreciate that my Tundra is at 2010 and I already take to the dealership and there's no codes no nothing the only problem is the fuel system that's no fuel on the engine they changed. Module and work for one day then this morning the truck start do the same thing
  4. Nov 11, 2018 at 5:10 PM
    trdprobped17
    So, the dealership said that it’s a fuel system problem? What did they say would fix it? If they replaced your fuel module and it only worked for one day, then I would take it back to them to fix it. Are you sure that there isn’t a leak somewhere?
    Again, I do believe that it is the fuel sending unit (pump). I had a similar problem with my wife’s 17 Sequoia, after it was rear ended. They fixed everything cosmetically, but, the truck wasn’t getting fuel to the engine. So, they had to replace the sending unit/fuel pump. It worked great ever since then.
    If it’s the sending unit, you will had to drop the gas tank, in order to be able to gain access to the fuel pump, so that you can replace it
