Stainless Steel Door Guards
Discussion in '3rd Gen Tundras (2022+)' started by backinblack, Apr 25, 2023.
  1. Apr 25, 2023 at 12:11 PM
    backinblack
    backinblack [OP] New Member
    James
    Anyone familiar with these? I've found multiple dealers adding these to Tundras. It's only $150 add on, but I'm more concerned with the aesthetic.
    Description says:
    Thermoplastic-coated stainless steel is precisely matched to the exterior finish.
    Compression-fitted to door edge contours
    Blend seamlessly to complement exterior styling
    If all that's true, they should barely be noticeable? Just curious if anyone has seen them in person?
  2. Apr 25, 2023 at 12:21 PM
    backinblack
    James
    Actually, got a picture faster than I expected. Seem to blend in pretty well!
    Mods - please delete thread if you want.
  3. Apr 25, 2023 at 12:27 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I have them and would want them on any new Toyota I would buy. Here is a quick picture. IMG_5354.jpg
  4. Apr 25, 2023 at 12:40 PM
    nodak67
    nodak67 New Member
    JR
    meh in 20+ years i have never needed those. what is the purpose of them except for peace of mind for the lazy? in ND with 15-25 mph winds daily, you learn to hold your door opening/closing them otherwise the wind will catch it and bend the door if not careful.
    Texan-1794 likes this.
  5. Apr 25, 2023 at 1:22 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    They come from the factory with them.
  6. Apr 25, 2023 at 1:40 PM
    nodak67
    nodak67 New Member
    JR
    they dont
  7. Apr 25, 2023 at 1:42 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Ya they do, mine were already on the doors when I went to look at the truck. factory add on.
  8. Apr 25, 2023 at 1:45 PM
    nodak67
    nodak67 New Member
    JR
    they dont come with the truck from the factory with them installed as standard. its and added cost.
  9. Apr 25, 2023 at 1:46 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    It was on my door sticker.
  10. Apr 25, 2023 at 1:49 PM
    nodak67
    nodak67 New Member
    JR
    did you buy yours in SET region? cause i know toyota usa regions its not a standard option. ask anyone not in SET/GST if they got door edge guards as standard
  11. Apr 25, 2023 at 1:52 PM
    nodak67
    nodak67 New Member
    JR
    then that means you paid for it. it wasnt free (standard option)
  12. Apr 25, 2023 at 1:53 PM
    nodak67
    nodak67 New Member
    JR
    saying every vehicle has it (standard) is not the same as paying for it.
  13. Apr 25, 2023 at 1:57 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Oh they charge for them. I think they were 165.They really pushed them in 2019, it seemed like most of trucks had them at the dealership. My daughters Tundra also came with then. I’m in the northeast. Never said it was standard. I said it came from the factory with them.
  14. Apr 25, 2023 at 2:03 PM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    My concern with those is the installation method. My wife's Forester had them factory installed, the instructions say to use a mallet to hammer them over the door edge. I can only imagine how much paint is lost in the process and what kind of future corrosion could happen. Not to mention, issues with stainless steel interacting with aluminum.
    Soupbean77 and WILLINH like this.
  15. Apr 25, 2023 at 2:19 PM
    nodak67
    nodak67 New Member
    JR
    which implies they are standard, which they are not. they are a PIO (port installed option) / DIO (dealer installed option). pio/dio options means that not every vehicle will come with them.
    i am guessing your region is making them mandatory, i know alot of other regions they dont add that as a PIO or DIO. kansas region 90-95% of the trucks i see do not have this PIO.
    each regional port has different mandatory requirements, so what may apply to your region may not apply to other regions. hence making the distinction. it will confuse people that are not in the know how FIO, PIO, DIO features work in different regions and what is considered standard and not.
  16. Apr 25, 2023 at 5:01 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    These were listed on the window sticker and cost extra.
    Mattedfred likes this.
  17. Apr 26, 2023 at 3:53 AM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    I planned on getting a set of these, but after seeing the installation instructions and where they’d make contact with the door seals when closed I opted not to.. have the same thoughts as you
    DMackler[QUOTED] and WILLINH like this.
  18. Apr 26, 2023 at 7:37 AM
    TheLordwoulddriveaTundra
    TheLordwoulddriveaTundra New Member
    2022 Tundra Platinum Crewmax 4WD, Mag Grey
    Talons Cat Plate Tuff Skinz Inserts RetraxOne XR Bed Cover Premium Shield PPF Revivify Coating OEM Console Safe WeatherTech Mats
    Yeah, I don't see the need but maybe others do. Over 20 years of driving and I have never once hit something with my door on edge. It doesn't stop door dings from others which as most could probably attest happens quite frequently. My doors are all PPFd.
  19. Apr 26, 2023 at 7:52 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    100% Stock
    can confirm that you do need to hammer them on. I bought a set and theyre hard plastic...dont think they scratch off the paint but theyve got to do some sort of damage if it takes a a rubber mallet to get them on. I live in Southern California, so corrosion is non-issue here.
  20. Apr 26, 2023 at 10:23 AM
    wayne73
    wayne73 New Member
    Wayne
    Minnesota
    2022 limited crewmax trd offroad
    I pulled them off my truck almost immediately. I did not care for the aesthetic look And I never park near any other cars. Pretty sure the dealer charged me $150 for them. But had no choice, since they were on the truck already. After a week of ownership this winter here in Minnesota salt and sand was already evident behind them. Just another place for salt to get stuck. I was a little worried that they were biting into the paint, since they were on there pretty tight, but there was no damage to the paint.
    DMackler and Mattedfred like this.
  21. Apr 27, 2023 at 8:20 AM
    Blistering fish
    Blistering fish New Member
    Blister
    2023 tundra 1794 iForce max TRD OR army green
    I have them as well. That’s how non intrusive they are.
    WILLINH likes this.
  22. Apr 27, 2023 at 10:16 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    I have always tried to be careful but things happen. The wind blows, a passenger slips
    Up. If you have kids you can tell them to do or not do something a million times, like be careful opening the doors, and they'll still slip up. The paint on those edges is weak and on some cars I've seen them chip making contact with something without much force at all. My partly disabled Dad when he was alive had to he watched like a hawk getting out of vehicles, otherwise he'd hit something with the door. You could tell him to wait but if you weren't fast enough he'd be swinging the thing Open before you could get there.
    These are cheap insurance and I've had L style 3m tape attached versions on my last several cars that go on gently and easily, don't come loose and saved me many times. I learned fast the cheap autoparts store glue on stuff is good for 2 really hot summers Max before you have a sticky mess with people getting glue on their fingers when touching the door edge. Never trusted the ones that clamp mechanically or get tapped on.
    The other day my kid who knows how I am and always tries to remember to Be Careful opened my truck door into the mirror of my other vehicle. Neither got paint damage because of the door edge trim.
    If you've managed a perfect track record your entire life more power to you but at 30 bucks to Cover all four doors I consider it cheap insurance.
    nodak67[QUOTED] and Mattedfred like this.
  23. Apr 27, 2023 at 10:57 AM
    nodak67
    nodak67 New Member
    JR
    its become 2nd nature to always hold onto to the door in ND. the only days the wind doesnt blow 15+ mph is the days you remember.
    snow and rain blow sideways here all the time.
    old adage is montana blows and chicago sucks and nd is in the middle
