SR5 advantages?
Discussion in 'General Tundra Discussion' started by coolbeans, Mar 19, 2022.
  1. Mar 19, 2022 at 2:25 PM
    coolbeans
    coolbeans [OP] New Member
    Is the SR5 with more sidewall in the tires overall better for washboards and ruts. Less gadgets that can break or wear on the battery? The only extra I really need is heated seats.
  2. Mar 19, 2022 at 2:26 PM
    Tires don’t effect the battery
  3. Mar 22, 2022 at 1:34 PM
    coolbeans
    I would probably go with an sr5 plus or sr5 sx.
    IsaiahCanada and Wallygator like this.
  4. Mar 22, 2022 at 1:39 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    7 year old platinum here that has had no electrical issues to speak of. this ain't your dads old GMC lol
  5. Mar 22, 2022 at 1:40 PM
    Coolbeans
  6. Mar 22, 2022 at 2:11 PM
    coolbeans
    How about the old gm breaking door handles? So annoying.
    PlatinumPro[QUOTED] likes this.
  7. Mar 22, 2022 at 6:10 PM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    Wear some long johns
    baraynavab and coolbeans[OP] like this.
  8. Mar 23, 2022 at 6:02 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Nah, just the tailgate handle on the Tundras.
    coolbeans[QUOTED][OP] likes this.
  9. Mar 23, 2022 at 7:45 AM
    coolbeans
    What do you prefer about the platinum? I see a fair bit of 1794 platinums for sale. Not sure if its because many were sold back then or people didn't end up liking them.
  10. Mar 23, 2022 at 7:46 AM
    2mchfun
    Get a 5.7 sr5 and spend the extra on a supercharger, long tube headers, gears, and brakes. You will arrive before your ass gets cold!
  11. Mar 23, 2022 at 7:49 AM
    18" TRD Off Road Wheels
    I wouldn't let the wheel/tire size dictate the trim. Buy one that has the features you want, and either trade or buy wheels in the size you want. More sidewall will be a cushier ride and better for airing down off road, but larger wheels with less sidewall will track better on pavement. All depends on what you want to do with your truck.
    coolbeans[OP] likes this.
  12. Mar 23, 2022 at 8:44 AM
    coolbeans
    So you can swap a stock 20" for a stock 18" wheel with no issues?
  13. Mar 23, 2022 at 8:50 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    2007-2021 you can fit as small as some 17" wheels or 18"s just fine. offset is important for oversized tires though. there was a factory 17 inch "rock warrior" wheel.
  14. Mar 23, 2022 at 9:23 AM
    Correct. Bolt pattern doesn't change so long as you are using the same generation of truck. So a Gen 1 Tundra can't swap with the Gen 2, and I think Gen 3 is all new. Basically, any stock 2022 Tundra wheel will fit any 2022 Tundra regardless of trim.
  15. Mar 23, 2022 at 3:14 PM
    PlatinumPro
    The 1794 and platinum are different models but both are luxury models that are only sold in crewmax. Leather, heated seats, roll down rear window, color-matched bumpers, shitty premium sound systems and 20" wheels.
    Not sure why you see an abundance of them considering they're the premium models and no, they're kick ass. The interior on my truck is by far my favorite of any truck ive been in.
  16. Mar 23, 2022 at 3:34 PM
    Kanobi13
    Kanobi13 New Member
    Sr5 you can add heated seats and suspension to butter up the wash boards.
  17. Mar 23, 2022 at 3:54 PM
    Blue By U
    Blue By U New Member
    I think Toyota is missing the fact that not everyone wants a 4 door short bed. No way I would own a crew cab short bed. Why did they not offer an extended cab with shorter wheelbase 6.5' bed or same wheelbase 7.5' bed.
  18. Mar 23, 2022 at 4:06 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I thought I read you can order a CM with 6.5 bed
  19. Mar 23, 2022 at 4:07 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Don't even need to stay stock lol aftermarket 18s fit
  20. Mar 23, 2022 at 4:15 PM
    Blue By U
    Maybe, but the wheelbase will be way to long.
  21. Mar 23, 2022 at 4:16 PM
    Kanobi13
    Kanobi13 New Member
    Way to long for what?
  22. Mar 23, 2022 at 4:22 PM
    Blue By U
    Turning radius could use some help. I've had my 2020 DC Sr5 almost 2 years and have not even put the rear seats down.
  23. Mar 23, 2022 at 4:23 PM
    The Double cab 6.5' bed and the CrewMax 5.5' bed are the same wheel base. Pretty sure they've been that way since gen 2. The CM 6.5' and the DC 8' share the same wheel base, IIRC. It simplifies production if you only have 1 or 2 wheel bases.
    Cpl_Punishment and coolbeans[OP] like this.
  24. Mar 23, 2022 at 4:26 PM
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    If you remove the rear seats it feels like a reg cab, just have more room to keep stuff from being stolen in the bed
  25. Mar 23, 2022 at 4:33 PM
    Blue By U
    I would pull the seats and build it out into something more useful. Nowhere to store the seat right now.
  26. Mar 23, 2022 at 4:51 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Nah. The rest of the truck world makes crew cabs w/8 ft beds. I love the longer rigs
  27. Mar 23, 2022 at 6:56 PM
    Blue By U
    I have some buddy's with CC 8ft beds and they take alot of room to turn around. I am just wanting a shorter cab and more bed with all the bells and whistles up front. Drop in campers would have more floor space, 2 dirt bikes would fit with the tailgate closed. Plenty reasons for the longer bed without making the truck longer.
  28. Mar 24, 2022 at 6:53 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Sounds like the DC is right up your alley
  29. Mar 26, 2022 at 7:53 AM
    coolbeans
    A double cab would actually have a lot of room coming from an extended cab.
  30. Mar 26, 2022 at 11:39 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Yes
    Doubtful
    Then get the SR5 with the lowest package that gets you heated seats (used to be called the Upgrade Package on the 2.5 gen) and save your money.
