Squeeking while driving bumps etc..
Discussion in '1st Gen Tundras (2000-2006)' started by SOLTENOFSWAT, May 8, 2021.
  1. May 8, 2021 at 5:30 PM
    SOLTENOFSWAT
    SOLTENOFSWAT [OP] New Member
    16' Limited Tundra TRD 4x4
    Front sway bar is touching the shock never noticed and just got the truck in feb so ive had hirrible squeeking past couple weeks mechanic noticed the swaybar touching but it wasnt squeeking when i took in for maintenance its getting worse though turns bumps even un even road while driving etc. Any idea what happened has it been in an accident? And can that be causing the squeeking? Or what can it be? Mechanic said bushing all looked good etc besides the bar. Should i just remove it to see what happens ? Left side pic is where i can show you i can fit a finger and right side pic is touching falken shocks came with the truck btw
  2. May 8, 2021 at 6:08 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Are the wheels evenly centered in the wheel wells, when comparing left and right sides?
    If the caster is significantly different it could bring the arm back, which would bring the shock back towards the sway bar. This could be as simple as needing a proper alignment to more involved problems like a bent control arm, etc.
  3. May 8, 2021 at 6:27 PM
    SOLTENOFSWAT
    Just set up an appointment for alignment next week too i hope that worksnoticed unevwn wear on tire so that for shure is a problem but waht about the squeeks could that be the arm ?thanks for your response
  4. May 8, 2021 at 6:53 PM
    SOLTENOFSWAT
    Just shot a laser level line and your right its off side to side and also they are both towed in ‍♂️
  5. May 9, 2021 at 6:02 AM
    Professional Hand Model
    Hand Protectors
    I can’t pinpoint it, but something about this setup doesn’t look proper.
    des2mtn likes this.
  6. May 9, 2021 at 9:41 AM
    SOLTENOFSWAT
    What are you thinking
  7. May 9, 2021 at 12:43 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    He's thinking it's not a 1st gen.
  8. May 9, 2021 at 12:59 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    Do 2nd gens have the same issues as 1st gens where the sway bar can shift left and right?
  9. May 9, 2021 at 1:22 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    CodyP and SOLTENOFSWAT[OP] like this.
  10. May 9, 2021 at 1:41 PM
    SOLTENOFSWAT
    Mine is 3rd gen and also i ended up getting my alignment done today and sadly that did not change anything as far as that sway bar touching and that loud squeeking im hearing ‍♂️@assassin1000
  11. May 9, 2021 at 2:03 PM
    Vizsla
    Vizsla 2 = 2.5
    Had squeaking in front on 2 of my tundras, ended up being bushings that isolate the condenser/trans-cooler from the flexing and vibrations of the radiator support.
    CodyP likes this.
  12. May 9, 2021 at 2:05 PM
    SouthWestGA
    SouthWestGA New Member
    I agree
    Is the truck suspension modified or lifted ?
  13. May 9, 2021 at 3:54 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Got a pic of the sheet? Did they do a toe set or actually change caster?
    Who does the alignment can make a huge difference.
    Also does the lower shock mount have spacers that could potentially be installed on the wrong side?
  14. May 9, 2021 at 6:27 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    I’m still leaning towards the sway bar has shifted to the side.
  15. May 9, 2021 at 8:37 PM
    SOLTENOFSWAT
    Not lifted jst had the falkens on it when i got it and i believe it was just the toe adjustment not the caster ill post the receipt it was done at bigO tires
  16. May 9, 2021 at 8:37 PM
    SOLTENOFSWAT
    Ill take a look at spacers and post that pic aswell
