squeek squeek squeek
Discussion in '2.5 Gen Tundras (2014-2021)' started by thebuildist, Apr 24, 2024.
  1. Apr 24, 2024 at 6:40 AM
    thebuildist
    thebuildist [OP] New Member
    Bob
    2017 SR5 Crewmax 4x4
    Rear seat storage
    2017 Crewmax 4wd, 150K
    When I'm rolling, in gear or not, I'm hearing a squeek squeek sqeek coming from the driver's side. My wife thinks she hears the rear wheel, I think maybe? the front wheel.
    It gets faster or slower depending on speed. Curves or inertia doesn't seem to affect it, but touching the brake pedal even a little bit will almost completely silence it.
    I've already removed the front brake pads and coated them and the caliper with quieting compound. No change.
    Stuck caliper? Wheel bearing? Does it ring a bell with anyone?
    How do I track it down?
  2. Apr 24, 2024 at 9:02 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Brake or wheel bearing could certainly do that. If your wheel weights are clip on vs adhesive, check those. They can squeak, chirp if they are loose.
    Based on your description however and that issue quiets with brake, look at the brakes again and lube those caliper pins and components, front and rear.
  3. Apr 24, 2024 at 9:07 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Definitely check your wheel bearings. Do you notice any difference with changing terrain? Any change when going over speed bumps or is it all the same? If so, your suspension bushings might be squeaking and quieting down when braking and force is applied to the suspension components. Bit of a long shot, but you never know.
  4. Apr 24, 2024 at 2:48 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    Don't overlook the possibility of a drive shaft U-joint. They can squeak if they are worn out or dry.
