Squeal when on the gas - drive shaft?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1UP, Feb 25, 2024.
  1. Feb 25, 2024 at 3:05 PM
    1UP
    1UP [OP] Truck Gang
    2019 Red CM TRD sport 4x4
    Got a squeal when I get on the gas. No noise when off the gas or going over bumps. I'm guessing it's the drive shaft.
    I haven't crawled up under yet. Is there a specific spot to lubricate?
  2. Feb 25, 2024 at 5:31 PM
    d33pt
    d33pt New Member
    Does it do it when you're on the gas in Park?
  3. Feb 25, 2024 at 5:38 PM
    windblown101
    windblown101 New Member
    2019 CrewMax Limited
    From your description I'd be thinking belt... but if it's clearly not coming from the engine bay then perhaps that's completely off base.
    Retired...finally and 1UP[OP] like this.
  4. Feb 25, 2024 at 5:45 PM
    d33pt
    d33pt New Member
    That's what i was getting at with my question. Never heard a driveshaft squeal.
    1UP[OP] and windblown101[QUOTED] like this.
  5. Feb 25, 2024 at 6:05 PM
    Retired...finally
    It's the natural noise the 5.7 makes. Look in the mirror for black streaks on the pavement.
    norma30a, 2mchfun, 1UP[OP] and 2 others like this.
  6. Feb 25, 2024 at 6:16 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    :101010:
    :mudding:
  7. Feb 25, 2024 at 8:09 PM
    1UP
    1UP [OP] Truck Gang
    That's a great way to isolate belt vs. drive shaft. I'll do that.
    Doesn't happen at start up and I'm sub 40k miles so I had assumed drive shaft and not belts.
  8. Mar 2, 2024 at 4:39 PM
    tufftundy11
    tufftundy11 New Member
    2000 tundra limited
    King shocks, spc upper control arms
    this is the most likely culprit! lmao
  9. Mar 2, 2024 at 7:09 PM
    1UP
    1UP [OP] Truck Gang
    Update - Sneaking a look under and I noticed the lines on top running into the pumpkin are on a clip. That clip appears to be slightly rubbing on the dirty deeds resonator.
    I'll have to adjust it and see if that solves it.
