Squeaky Hood Release
Discussion in '2nd Gen Tundras (2007-2013)' started by akielb, Aug 20, 2020.
  1. Aug 20, 2020 at 11:35 AM
    akielb
    akielb [OP] New Member
    2011 White Crew Max Grade
    After much worrying that I had something expensive squeaking in the front end I found that the hood was what was squeaking. I can move the hook a good 1/2 to 3/4 inch and in that the hood release is squeaking against the catch.
    Thoughts on a fix? Is there some play on the hood latch I should attempt to move? Is there a plastic cover missing on the catch?
    This is where the squeak is
    Thanks,
  2. Aug 20, 2020 at 1:53 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    some chassis grease will fix it, even a shot of wd40 would probably keep it quiet for a while. Friction points like that on any vehicle should be lubed every year or so- door and hood hinges, tailgate, if it moves throw some lube at it occasionally.
