Squeaking squeak
Discussion in 'Suspension' started by Payaso 9394, Aug 5, 2017.
  1. Aug 5, 2017 at 12:35 PM
    Payaso 9394
    Payaso 9394 [OP] New Member
    Ricky
    La Puente CA
    16' Tundra 2wd CrewMax 5.7l
    Tint, 33x12.5r18
    Hi everyone I had a question or problem I need help with.. my front end has been doing some squeaking and the issue looks as if it's coming from the icon ucas. The other squeak come from the back of the truck it looks like the bolts from the leaf springs that are by the rear door. Has anyone had any issues like these and are there any fixes.
  2. Aug 5, 2017 at 1:03 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Squeaking squeak???? Is that a lesser form of clunking clunk?
    How many squeaks could a squeaking squeak squeak out if a squeaking squeak could squeak?
    Dry grease or some good auto lube on the spring bolts and grease up the zerks on your ball joints you should be good to go.
  3. Aug 5, 2017 at 1:18 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Would I have to remove the bolts?? And hahaha that's a good one I could barley read it all
    Law323 likes this.
  4. Aug 5, 2017 at 2:45 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I could barely type it! LOL
    I'm not entirely sure if you'd have to remove the bolts. I'd spray some on and see if it works, if not then remove the suckers.
    Also spray some on the ends where the springs attach to the bed. That could be where it's coming from.
  5. Aug 6, 2017 at 11:35 AM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Aight I'll try it out hopefully it goes away
    Law323 likes this.
  6. Aug 6, 2017 at 11:46 AM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    My rear leaf springs were squeaking pretty bad after I did some offroading in the sand. Tried pressure washing and cleaning them out and still squeaking! (Only 14k miles on the truck)
    I used a motorcycle chain lube across the whole leaf pack and have been squeak free since! As far as your UCAs I don't have aftermarket ones so someone else can chime in for that!
  7. Aug 6, 2017 at 1:08 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I thought from the thread title we were talking about a squeaky bed..........
    Hope you figure it out!
