Squeaking left suspension
Discussion in 'Suspension' started by Thattundradude, Jan 28, 2020.
  1. Jan 28, 2020 at 7:31 PM
    Thattundradude
    Thattundradude [OP] New Member
    Platinum Tundra
    Lifted
    Hi all, really hate this noise that's coming from my front left, occurs when going over bumps or shaking the truck. Video link attached. Any help is highly appreciated.
    https://youtu.be/a7ZzrqagA60
  2. Jan 28, 2020 at 7:46 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Very tough to tell from just your vid but if it was mine, i would spray every movable joint individually with something like a PB Blaster to isolate the offending squeak. In my opinion, it will probably end up being one of the rubber bushings..Good luck.
    Thattundradude[OP] and 15whtrd like this.
  3. Jan 28, 2020 at 7:54 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  4. Jan 29, 2020 at 8:45 AM
    Rebel Tundra Man
    Rebel Tundra Man New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    Mine squeaks on the driver side rear leaf spring pack. I don't know what it is but I just send it anyways.
  5. Jan 29, 2020 at 9:42 AM
    Thattundradude
    Platinum Tundra
    Lifted
    I think I might have a can of wd40 laying around
  6. Jan 29, 2020 at 9:44 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Sounds like a dry bushing start lubricating everything.
    Thattundradude[OP] likes this.
  7. Jan 29, 2020 at 10:26 AM
    TheBeast The Beach
    squeaking like a cheap bed in a cheap motel...
    denteen likes this.
  8. Jan 29, 2020 at 10:37 AM
    Wldkatz03
    Wldkatz03 New Member
    Michael
    2019 Toyota Tundra 1794 Edition 4x4
    I had a squeak on the driver side a while back...had it in the dealership for my service and had them check it out. They ended up replacing the shock/strut.
  9. Jan 29, 2020 at 10:57 AM
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    Bad ball joint
  10. Jan 29, 2020 at 11:06 AM
    15whtrd
    15whtrd Mr. Blonde
    I had a squeak on the passenger side front area. Replaced my coil overs and lifted the truck. No more squeak LOL.
  11. Jan 29, 2020 at 1:40 PM
    Thattundradude
    Platinum Tundra
    Lifted
    I think my tie rods are bad keep forgetting to check them. My wheel does shake at 55
  12. Jan 29, 2020 at 1:56 PM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Spray the bushings with PB blaster and test drive, if noise goes away, bushings, if not, most of the time it's a ball joint.
  13. Jan 30, 2020 at 6:09 PM
    Thattundradude
    Platinum Tundra
    Lifted
    I sprayed a bunch of wd40 over everything still squeaking
  14. Jan 30, 2020 at 7:00 PM
    xtyfighterx
    Ty
    North Idaho
    Probably the shock then
  15. Jan 31, 2020 at 12:59 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    Jack the tires up and look. Wiggle the tire side to side, then up and down, should be tight. Now do big turns with the tire and see if it's smooth or the ball joints are sticky, dried out, and causing your squeak. WD/40 does not work as good as PB or something more oily per say. WD/40 is used to spray on metal to keep it from rusting. Water Dismemberment 40th formula finally worked. Developed for the military.
  16. Jan 31, 2020 at 7:10 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    I'll bet my paycheck that it is the Lower Ball Joint.
    Ask me how I know......
  17. Jan 31, 2020 at 7:40 AM
    Thattundradude
    Platinum Tundra
    Lifted
    Lol let's find out. Going to try PB blaster tonight too
  18. Jan 31, 2020 at 7:52 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    When that started on my '04 about 2K miles after I put in new ball joints, I sprayed white lithium grease on it and it stopped for a week or so. Finally decided to replace them again with a better quality ball joint WITH grease zerks, it stopped completely. The zerks are important as you can shoot a little grease in them now and then and keep them lubricated.
    Luckily, it's an easy job (with the right tools of course) and only takes about 15 minutes per side.
    Get a ball joint separator from HF and if you have any mechanical ability at all, you can do it in your garage or driveway.
    denteen likes this.
  19. Jan 31, 2020 at 3:52 PM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    I bet it's the lower BJ as well.
  20. Jun 12, 2020 at 5:39 AM
    denteen
    denteen New Member
    2002 Tundra SR5 2wd
    Nada
    Tagging onto this as I Just bought a one owner 2002 with 166k and it is squeaking there as well. Will have a look at the ball joints. Seems to be a weak spot as Im looking around the forum. thanks guys.
  21. Jun 12, 2020 at 7:09 AM
    King R 808
    King R 808 New Member
    Ryan
    2020 White Tundra TRD Pro
    Holy shit i have this exact same issue on my 2020 also. I took it to the dealership and they said the hood was loose and they fixed. When i left the dealership PARKING LOT the small bumps to get on the main road it started again. the noise doesn't happen all time but when it does it annoys the shit out of me. I haven't gone back to the dealership yet but plan to this coming week. I paid a pretty penny for the truck and hate that it has this issue.
  22. Jun 12, 2020 at 9:00 AM
    Sounds like morons at your dealer. The hood?....that's the best they could come up with?
  23. Jun 18, 2020 at 12:05 PM
    fytedapowr
    fytedapowr New Member
    Jake
    Austin TX
    '15 1794 4x4
    Bilstein 6112/5160, CB +2 shackles, SPC UCA's, CB bumper shims, 35's
    Gen 1's have LBJ problems that are less common in later models (changed design). I have a similar squeak on '15 that I'm thinking is my LCA bushings having been tightened without truck weight on them. Checking this weekend
  24. Aug 22, 2020 at 12:39 PM
    denteen
    denteen New Member
    2002 Tundra SR5 2wd
    Nada
    I just changed my front strut setup. Ended up going Monroe quick strut as some other options weren’t available.
    Solved some really bad suspension issues, but also solved my left front ‘squeak’ that was driving me crazy. thank God! Not ready for all the balljoint/bushing replacements yet
  25. Feb 11, 2022 at 9:55 AM
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    2017 Super White Tundra Platinum CM
    285/70r18 NITTO RG | Method NV 18x9 | Bilstein 6112 @2.5" w/CB shims, SPC UCA, 5100 & CB +3 Shackles | Entune 3.0 Swap | 2018+ Platinum grille + Pro LED Headlights
    I have this EXACT noise on the driver side too. Did anyone ever find a solution? I have SPC UCAs and thought maybe they needed re-greasing.
  26. Feb 11, 2022 at 10:06 AM
    Are you positive that it is in the front? I had that noise and it was the driver's side leaf spring.
  27. Feb 11, 2022 at 10:12 AM
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    100% sure. its exactly like this video.
  28. Feb 11, 2022 at 10:15 AM
    Gotcha. It sounds like a dry bushing. Someone needs to be under there to track it down.
  29. Feb 11, 2022 at 10:18 AM
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    I loosened the nut and slid the bolt of the UCA out a little to grease the outer parts of the bushing, which helped a little, but overall its still there. Guess I have to find the time to remove the entire UCA and re-grease everything. What a PITA.
  30. Jun 22, 2023 at 4:38 AM
    Adventundra
    Adventundra New Member
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    I have this same annoying squeak on my ‘01….again….after I replaced the LBJ!! Which fortunately snapped while sitting in the driveway and not while I was driving.
    My mechanic used a MOOG LBJ though….the squeak stopped after the new LBJ….but now it’s back….after only 4 months!!!
    Shouldn’t I just be able to spray the LBJ with lubricant since it’s new??
