Squeaking is Driving Me Crazy
Discussion in 'Suspension' started by mistert, Mar 7, 2020.
  1. Mar 7, 2020 at 3:19 PM
    mistert
    mistert [OP] New Member
    Michael
    '16 Tundra TSS Offroad
    Rack with LED lights, carbon fiber wrap, bumper with winch, rear bumper, lift, and Moto Metal tires.
    I purchased a 2016 Tundra towards the end of the year last year and one thing that drives me nuts is how my Tundra is making this noise. I thought for sure it was something to do with the brakes because I hear it worse when slowing down to a stop. I started to notice that I would hear the same noise though when I am turning right and moving slow. I took it to a tire shop the first time who told me that I needed my rotors turned and new brake pads. I reached out to the dealership where I had purchased the vehicle who finally agreed to take a look. They turned the rotors and replaced the pads, but the next day, I am pulling out of my circular drive that is on an incline, and I hear the same noise. I brought it back to the same tire/brake shop who looked and verified that the rotors were turned and the pads replaced and said it was probably the bushings causing the noise.
    I sprayed every bushing I could see after watching videos on YouTube with silicone lubricant and the noise still persists. A few weeks ago, I took the truck in for an oil change and had the Toyota dealership look into the noise that the truck is making. They reported two issues. They said that there is squeaking coming from the front struts and that the sway bar is rubbing the bump stops.
    I do hear squeaking when going over bumps and if I drive with the windows down and the radio low or turned off (that is most likely coming from the struts). How would stopping and turning right be causing the other noise if it is coming from the sway bar? I have the tires turned trying to see where it could be rubbing, but can't see where it is happening.
    My wife rolls her eyes and tells me just to turn up the stereo so you don't hear it, but damn, I am driving a '16 and it sounds like I am driving an old clunker. The squeaking from the struts is not as bad as the noise coming from when I am turning the truck or coming to a stop (which was why in the beginning I was sure it was the brakes). I have heard of people removing the front sway bar in some cases. I don't do any off roading and use it more for a daily driver. It is a 4x4 TSS edition with what looks like around a 3" leveling kit with stock struts. What would you recommend?
    Tundyfundy likes this.
  2. Mar 9, 2020 at 9:48 AM
    mistert
    Michael
    I may just remove my sway bar and see if it eliminates some of the noise that I am getting and see how it drives as far as body roll.
  3. Mar 20, 2020 at 4:24 PM
    mistert
    Michael
  4. Mar 20, 2020 at 5:02 PM
    unclebeejo808
    unclebeejo808 New Member
    Oahu
    Did you check the skid plate? Mine was missing the two front bolts and it squeaked like hell.
  5. Mar 20, 2020 at 5:13 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Just trim the edge of that bump stop and see if it helps.
    Tundyfundy and FrenchToasty like this.
  6. Mar 24, 2020 at 7:15 PM
    Tundramon'
    Tundramon' New Member
    2016 Platinum Tundra 5.7 4wd
    Maybe check the dust plate. It used to happen in my 05 tundra. Maybe have to bend outward a lil. I never really looked under the 16 yet
  7. Mar 24, 2020 at 7:25 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Spring purch on strut. Try some WD40 oil on each end of coil spring. Mine had a leaf spring squeak after it got lifted with a block in the back. Also possible the shackles to leafs. Give them a shot of WD at rubber bushing.
    Not the nuts...lol
    Good luck.
  8. Apr 17, 2020 at 9:40 AM
    rwright
    rwright New Member
    Washington
    2016 Tundra TRD Pro Super White
    Complete LED conversation (Headlight Revolution and deAuto LED) Ditch Lights(Cali raised) weather Tech, undercover bed cover
    I bought a 2016 TRD Pro about 6 months ago and it started squeaking too. Re torqued those skid plate bolts and it stopped immediately.
    Blueline, Inquiringone and Tundyfundy like this.
  9. Apr 20, 2020 at 6:13 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    Try removing the front sway bar. If the squeaking is still there and you have checked torque on everything else, my bet would be a lower ball joint.
    Ask me how I know......
  10. Apr 20, 2020 at 6:41 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    For what it's worth, my 2018 Sport had a similar issue, only right turns and it would rub/squeak or creak on right turn, incline parking lots (right turn) bumps etc, left turn doesn't do it. The noise is always there, if you made a 360 degree circle and jerk the wheel, the noise is super obvious, again left turn 360 is dead quiet.
    So after 2 days the tech at our local Toyota found the issue, it had to do with the brake lines rubbing against the body/frame when making that right turn.
    Originally, he did a very thorough job by looking at the entire engine bay, zip tieing everything and inside the cabin as well. I'm glad he found it. Since then , there was is no more noise.
    I don't know exactly where the fix is but the service rep told me that the tech insulated it. Worth taking a look.
  11. Apr 20, 2020 at 7:22 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Any reason your tie rod is mounted on the top? It should be coming in from the bottom with the nut on the top?
    TRD Pro Rookie, Twinky and rebmo like this.
  12. Apr 20, 2020 at 7:46 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Ditto. Fix the tie rod ends.
  13. Apr 28, 2020 at 6:15 AM
    Kenny1794
    Kenny1794 New Member
    I recently had a squeaking sound, and thought it was sway bars, come to find out when my mechanic put my suspension on as we was talking he touched the tire under neath the truck, and it moved i drove it to see if noise was still there which it was, then i tightend the tire and no more noise. The sound was a squeeking noise when i stopped, accelerated, hit a bump, and turned left or right.
    rebmo likes this.
  14. May 2, 2020 at 4:23 PM
    mistert
    Michael
    The spare tire? Mine was loose, but the dealership determine it was the struts squeaking. They also noted the sway bar was hitting the bumper stops. I am thinking of removing the sway bar and seeing how I like the handling after reading reviews. The front struts might be replaced down the road.
  15. May 2, 2020 at 5:21 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    How do you know??
  16. May 2, 2020 at 6:16 PM
    P-Factor
    P-Factor New Member
    :pccoffee:
  17. May 2, 2020 at 7:31 PM
    Kenny1794
    Ok cool
  18. May 3, 2020 at 1:19 PM
    Inquiringone
    Ter
    NorCal 408
    I have a set of hole punches that range from 1/4” to 2.0”
    I used some thin rubber to sandwich between the RCI skids and cross members.
    I ended up selling them off to @joonbug. Now I’m wondering if he’ll use them on his new build to end squeaks
    :confused::cool::p
  19. May 4, 2020 at 5:53 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    Because I went through the same thing about 2 years ago on a Tundra. Drove me crazy until I found it was the lower ball joint. Easy to replace though
    Tundra_361[QUOTED] likes this.
  20. May 4, 2020 at 10:04 AM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    I’m getting a squeak and trying to pinpoint where it’s coming from. Frustrating
  21. May 4, 2020 at 10:10 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    Doe it squeak when sitting still and turning the wheel? Slow driving over undulations in the road?
  22. May 5, 2020 at 10:21 AM
    King R 808
    King R 808 New Member
    Ryan
    2020 White Tundra TRD Pro
    Holy SHIT! This squeaking is killing me also. I have 2020 Tundra TRD Pro and it seems like it getting worse. I'm about to make an appt at the dealership also because for some reason the rear a/c is not blowing. Not sure if it ever was either because i never sit there. Honestly though the squeaking almost sounds like the shocks are bad because its every minor bump, when i stop, or accelerate. But after reading all the posts on here it sounds like the dealer will tell me to pack sand.
  23. May 7, 2020 at 5:30 AM
    It may vary between 2wd and 4wd? Mine is mounted just like his.
  24. May 19, 2020 at 3:52 PM
    My spare is what was causing my squeak.
  25. May 27, 2020 at 9:11 PM
    itsmerh85
    itsmerh85 New Member
    Gilbert, AZ
    2020 Black TRDPro
    Did you tighten the spare, or did the dealer find anything else?
  26. May 27, 2020 at 9:30 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    My leaf springs get a really loud squeak every once in a while, mostly the drivers side. There's a small gap in between each leafspring and blasting them with water and then a little spray lube shuts them up. Just something to check if you've checked everywhere else. You should be able to get your shoulder into the wheel wheel and rock the truck up and down to check it
  27. May 27, 2020 at 9:44 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Would you have a pic of how you did it. Thanks
  28. May 29, 2020 at 4:48 PM
    mistert
    Michael
    The dealer tightened the spare and said that it was sway bar rubbing against the bumper stops and part of it is from the front struts. I sprayed the shit out of the struts with industrial strength silicone lubricant hoping it would fix the issue but it still squeaks like an old truck.
    I plan on removing sway bars but have been busy with a lot of other projects.
    itsmerh85[QUOTED] likes this.
  29. Mar 28, 2023 at 8:18 AM
    reco4738
    reco4738 New Member
    Renzo
    Austin, Texas
    2021 Toyota Tundra 1794 Edition w/ TRD Off Road
    Hey man!
    You just described to a T my exact same issue. Same squeaking you're hearing. Same situations when I slow down or turn right. I cant tell you if it's there when I drive because once windspeed picks up I can't hear it anymore.
    I know these are trucks but it gets worrying when it comes out of nowhere.
    Did you ever figure it out or can you post a video of the noise?
    Anything will help! Thank you!
  30. Mar 28, 2023 at 8:32 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Mine is driving me nuts as well. Either a UCA or my swaybar. I can rock the truck slightly on the passenger side and it squeaks. I tried to use silicone lubricant, but the area is tight it doesn't penetrate. I read that plumbing tape on the rod and lube is the only real solution.
    Just not ready to pay to have that done
