Squeaking from engine when accelerating??
Discussion in '2nd Gen Tundras (2007-2013)' started by Dirtoholic, Aug 10, 2020.
  1. Aug 10, 2020 at 9:32 PM
    Dirtoholic
    Dirtoholic [OP] New Member
    Peoria az/San Diego ca
    11 tundra limited 4wd
    6” rc lift
    2011 tundra limited 5.7 squeaking when pushing on the gas pedal (no other time) it sounds like a bad serpentine belt or pulley but I already replaced and it still doing it. I disconnected the serpentine belt and accelerated for about 10 seconds and it still squeaked.. it doesn’t do it if the truck is in neutral or park. Only when driving. Any idea how to fix?
  2. Aug 10, 2020 at 11:08 PM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    Water pump? Drive through a puddle or get the engine wet? Could also be simply time for a new water pump. As it dries more it will get worse, until you can't think anymore.
  3. Aug 11, 2020 at 5:14 AM
    YotaFan05
    YotaFan05 New Member
    NE OH
    2011 Tundra Crewmax
    Not sure if it's the same noise, but mine made more of a whistling noise during acceleration. Turns out, these trucks do that with an aftermarket air filter... I've got a k&n filter.
  4. Aug 12, 2020 at 2:50 AM
    ionnaeus
    ionnaeus New Member
    Jon
    Chattanooga, Tennessee
    2018 Limited CM MGM 5.7
    Changed the belt but could it be a bearing going bad? New belt = more tension + acceleration. Just a thought.
  5. Aug 12, 2020 at 5:12 AM
    Toytock
    Toytock New Member
    Jeremy
    ND
    2015 Tundra TRD Pro
    Check your u joints? If it only does it gear, it may be a driveline issue
  6. Aug 12, 2020 at 10:48 AM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    The Idler\Tensioner pulley is usually the first to go.. Did you figure it out yet?
  7. Aug 17, 2020 at 9:24 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    @Dirtoholic is the squeak from the engine or just from some were up front? does the squeak get louder with increased RPM or is a consistent squeak?
  8. May 17, 2022 at 7:56 AM
    Killahill
    Killahill New Member
    2015 Toyota Tundra
    All this and no solution found? Still squeaking?!
  9. Dec 6, 2023 at 11:37 AM
    mrballcb
    mrballcb New Member
    Todd
    2008 Grey Tundra CrewMax Limited TRD 2x4
    Black nerf bars
    Does this sound like the noise you're describing?
    @YotaFan05
    I'm describing my noise as a "whistle" not as a squeal or whine. In my case, the speed of the motor does not cause the whistle, but rather the torque demand (hard acceleration makes motor suck in lots more air). I haven't yet been able to isolate where exactly it's coming from because it doesn't make the noise at idle, it doesn't make the noise at any no-load revs ... it only does it when hard accelerating.
