Squeaking at standstill and low speed
Discussion in '1st Gen Tundras (2000-2006)' started by Jays06, Feb 27, 2024.
  1. Feb 27, 2024 at 9:43 PM
    Jays06
    Jays06 [OP] New Member
    Jay
    2006 Tundra Limited DC 4x4
    80%Fabrication rear bumper, front bumper, and sliders JBA UCA’s Front- Icon 2.5 coil overs with 700lb Eibach springs Rear- Icon 2.0 shocks & Icon AAL Siberian Poly LCA Bushings Poly Steering Rack Bushings JBA Poly UCA Bushings
    I have a 2006 tundra limited 4wd. It has a 2.5” icon coil overs and eibach and JBA uca’s. Running 33”KO2’s. I’m hearing a squeaking noise when I’m parked and I turn the steering wheel or if I’m at a slow roll and turn the wheel. I just bought the truck and don’t know if the previous owner greased the bushings or balls. I just greased the upper bushings and ball with Mobil 1 lithium grease and still squeals.
    Does anyone have some input on what may be wrong?
  2. Feb 27, 2024 at 9:56 PM
    Jays06
    Jay
    Oh and I also have the energy suspension red steering rack bushings
  3. Feb 27, 2024 at 9:59 PM
    LBJs are the biggest worry.
    The Black Mamba likes this.
  4. Feb 28, 2024 at 3:13 AM
    Poly bushings are notorious for squeaks, especially if the person who installed them is ignorant to the need for poly-safe lubricant anywhere the poly touches metal, or lubricant has diminished over time. You can potentially test if poly bushings are the source by dousing any seam of the bushing with silicone spray and see if the squeak diminishes, but this is not a definitive test, because there's no way to force penetration of the lubricant. White lithium grease is poly-safe also, but silicone lubricants (silicone in gel format) is best.
    That said, I also want to emphasize what @KNABORES said, that the LBJs are a huge fail point, and the biggest mistake people make with LBJs is buying non-OEM replacements, because aftermarket LBJs are notorious for having a substantially high failure rate, short life span.
    Have you done any inspection at all, typical wheel push/pull/slap test to check bearings, BJs, tie rods with one front wheel jacked up at a time?
    Have you jacked up both front wheels and tested steering left/right while you're SAFELY under the truck with the e-brake engaged, and a friend is going lock-to-lock on steering (with truck running) so you can see if the squeak is coming from the rack?
    If you've not done the above two steps, I don't see how we can proceed with advising you on what it could be.
  5. Feb 29, 2024 at 12:47 PM
    Jays06
    Jay
    So as soon as I heard the squeak I greased the poly bushings and the upper ball joint with lithium grease. I lifted the front end and steering from left to right was no squeaking. As soon as I put the wheels back on the ground and slightly turn either way it squeaks. I will do the wheel bearing check today
    KNABORES likes this.
  6. Feb 29, 2024 at 1:01 PM
    Ball joints
    shifty` and FishNinja like this.
  7. Feb 29, 2024 at 2:49 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Can you clarify this part. You have ICON coil overs and JBA UCA's. What part is made by Eibach?
  8. Feb 29, 2024 at 2:54 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    I’m like 90% sure Eibach springs is what he meant
    Just cause eibach makes springs for a shit load of companies. Just like the TRD springs are eibach.
  9. Feb 29, 2024 at 2:56 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I have ICON coil overs but I didn't realize they offered them with Eibach springs.
    I didn't think ball joints were known to squeak but I agree they should be inspected.
  10. Mar 5, 2024 at 6:20 PM
    Jays06
    Jay
    Yes they are eibach springs. I purchased the truck like this. I will be replacing the lbjs and go from there.
  11. Mar 5, 2024 at 6:22 PM
    BJ will squeak (creak) if dry.
    Jays06[OP] likes this.
  12. Mar 21, 2024 at 1:32 PM
    Jays06
    Jay
    Switched out lower ball joints with oem lbj’s and also installed new JBA upper ball joints. Will see how it drives on the way to the alignment shop. Hopefully the squeaking is gone. If not I’ll probably be looking into the steering rack next.
    Diablo169 and shifty` like this.
  13. Mar 22, 2024 at 1:20 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    Ball Joints and TRE’s are more of a Creaking than a Squeaking.
    Squeaking is mostly Rubber or Poly contacting Metal.
    shifty` and Jays06[OP] like this.
  14. Mar 22, 2024 at 1:25 PM
    FishNinja
    Lee
    06DC2wd
    this. Metal on metal is a very distinct sound
  15. Mar 25, 2024 at 8:57 PM
    Jays06
    Jay
    It was the passenger side lbj was bad. Took it out to ocotillo wells for some trailing over the weekend and did excellent.
    shifty` and bmf4069 like this.
  16. Mar 25, 2024 at 8:57 PM
    Jays06
    Jay
    Thank you all for the help!
    shifty` likes this.
