squeak noise when I applying soft press on brake pad
Discussion in '3rd Gen Tundras (2022+)' started by phil1419, Feb 13, 2024.
  1. Feb 13, 2024 at 1:53 PM
    phil1419
    phil1419 [OP] New Member
    2023 silver tundra 1793
    why my new 2023 tundra 1793 makes a squeak noise when i put brake in slow speed? forward and backward. technician at dealership service could not find problems in the brake system.
    is anyone have this problem?
    when I mention this problem, they said they are aware of this problem and they are working on it. it's been one year!
  2. Feb 13, 2024 at 2:08 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Hi from PA!
    Can't help you on the noise......
  3. Feb 13, 2024 at 2:12 PM
    Good luck with this. Universal issue with ceramic brakes. Has to do with vibrations. Very light application of brakes causes vibration like when you run a finger around the top of a crystal glass and make it sing. That’s why it doesn’t do it when you press harder. The additional pressure makes the vibration stop. Using a brake grease on the BACK of the pads where they contact the pistons can help. Spring tension clips can help as well. But those ceramics just like to sing.
    wing-2 likes this.
  4. Feb 14, 2024 at 2:45 AM
    wing-2
    wing-2 New Member
    Thanks.
