Squeak and creak
Discussion in '2nd Gen Tundras (2007-2013)' started by Brandenmontoya10, Jul 20, 2018.
  1. Jul 20, 2018 at 6:05 AM
    Brandenmontoya10
    Brandenmontoya10 [OP] HE > I
    Branden
    2011 Tundra Charcoal Grey
    Howdy! My 2011 tundra is driving me nuts. (3” lift in front, extra leaf in the back (5) total) I get a high pitch creaking noise from both sides. The noise is generated by compression. I scilicone lubed the leafs, u-bolts, and pretty much every piece of suspension I could see. Noise went away for a day and then came back. Any ideas? I’m going nuts here lol God bless brothers & sisters!
    Black Wolf likes this.
  2. Jul 20, 2018 at 7:08 AM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Did you have a spray in bedliner done? If so, check the bed bolts. Torx 55 I believe. Mine were loose AF, I torqued them to 65ft lbs and raised my shackles that were rubbing on the bed bolts and my squeak went away entirely. What type of leaf spring bushings are you running? Stock or poly aftermarket?
  3. Jul 20, 2018 at 8:33 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Noise coming from the front or rear?
    TheBeast likes this.
  4. Jul 20, 2018 at 8:35 AM
    Brandenmontoya10
    Branden
    No spray in. Just plastic Bed liner. I believe they are stock. I bought the truck with the lift already in place. It’s was professionally done by CST (California super truck) the dude payed 5k for it =O
  5. Jul 20, 2018 at 8:35 AM
    Brandenmontoya10
    Branden
    New
  6. Jul 20, 2018 at 8:36 AM
    Brandenmontoya10
    Branden
    Driver side sounds like rear upper area and passenger side sounds like lower center of truck. When you get under it it sounds like it’s coming from everywhere
  7. Jul 20, 2018 at 8:43 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Lol. Maybe try an automotive stethoscope?
  8. Jul 20, 2018 at 10:29 AM
    Brandenmontoya10
    Branden
    Does anyone know where the bed bolts are located on the 2011 tundra?
  9. Jul 20, 2018 at 10:41 AM
    15whtrd
    15whtrd Mr. Blonde
    In the bed. 6 big torx bolts
    Tundyfundy and TheBeast like this.
  10. Jul 20, 2018 at 10:47 AM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    My leaf springs started to make some noise after a trip to the sand dunes. And lots of dusty desert trips. Tired power washing and cleaning and didn’t help. I jacked up the rear to open up the leafs and washed and scrubbed the leafs again and sprayed motocross chain lube on the leafs. (Lubricant that dirt does not like to stick too) and so far it’s been quiet since. Most other lubricant will attract more dirt causing more noise. Just my opinion and something to try out if it’s coming from your rear suspension.
    15whtrd, Sas, Pale_Horse and 2 others like this.
  11. Jul 20, 2018 at 11:46 AM
    TheBeast The Beach
    +1 bannock452
  12. Jul 20, 2018 at 2:31 PM
    Brandenmontoya10
    Branden
    Solid info. Thank you. I trying using a compressor to blow the dust out, then used PB blaster. Maybe pressure rinsing is a better alternative. Any opinions on scilicone PB blaster? Do you suggest another lube? It didn’t work last time but maybe skipping the pressure wash stage was a bad idea
  13. Jul 20, 2018 at 2:35 PM
    TheBeast The Beach
    I used WD40 white silicon grease. worked great for my squeaking/creaking.
    15whtrd likes this.
  14. Jul 20, 2018 at 8:08 PM
    15whtrd
    15whtrd Mr. Blonde
    Yup!
  15. Jun 12, 2019 at 11:38 PM
    Rickydoo
    Rickydoo New Member
    Black Tundra
    Lift
    I had the same problem and finally fixed the issue!! The sound could be coming from the front skid plate if there is a bolt missing or loose, but in my case it ended up being an exhaust hanger that was rubbing against the middle part of the truck on the metal frame. The Tundra has a mid-hanger that may slightly shift and cause metal to metal contact when going through several small and continuous bumbs in the road causing an annoying squeak and creak. A trip to the exhaust shop fixed the issue when the hanger rod was modified to allow for more free moving clearance.
