Squadron Pro vs XL Pro
Discussion in 'Baja Designs' started by Baja Designs, Jun 23, 2023.
  1. Jun 23, 2023 at 1:23 PM
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    At Baja Designs, we get a handful of questions about the lighting packages we sell and how they perform. With these questions popping up frequently we decided it was time to let that cat out of the bag and share some night output shots of two of our commonly compared lights. On paper, the Squadron Pro and XL Pro look to perform similarly but most ask why the price tag says otherwise. White both lights are designed with the top quality CREE LEDs, Thermal Management, and Copperdrive circuit boards the light is also affected by the surrounding components.
    In this post, we would like to highlight just how important those surrounding components affect the light's performance. The surrounding components that I am referring to in this product case are the large light housing and the deeper optical reflectors as well as a smaller housing and smaller optical reflectors.
    Squadron Pro Spot Single Light
    ePFzn0pU9JQUyGCH9j5lvE2Mbg2nfuJGO_HKZsno_e77514ad58d07c0fa7551e2ebbebdd2fc1e21126.jpg
    WcQt935NdWi0wiMrGZbwtaRfaYax9XV5T3aM_qiw_30b8bc9746ae42a76ef5606326296f789b4b08e4.jpg
    Squadron Pro Specs
    Amperage Rating (A):3
    Average Rated Life (hr.):49,930
    Beam Pattern:Spot
    Bezel Material:Billet Machined Aluminum
    Brightness (Lumens):4095
    Description:Spot; Clear
    Housing Color:Black
    Housing Material:Hard Anodized and Powder Coated Cast Aluminum
    Lens Color:Clear
    Lens Material:Hardcoated Polycarbonate
    Light Quantity:1
    Lighting Modes:Beam
    Lighting Quantity:4
    Lighting Technology:Cree LED (2 Types)
    Lighting Type:Forward Projecting
    Mounting Hardware Included:Yes
    Mounting Hardware Material:Stainless Steel
    Overvoltage Protection:Built-In
    Product Type:Squadron Pro LED Light Pod
    Wattage (W):41.400
    XL Pro Spot Single Light
    HhGeY2O3iwBjoDL0Rm5GUBXs7y-U3itHyQWTgwG4_5c841142f7fcab26bcd367cf7c174cb2a3ff4f56.jpg
    ikitk1rH1kN3f9KM_cSMHFUY_2lR1bar5MnZclNA_763d08aea7edfd3ee7c269a590dcbc6ebbe90067.jpg
    XL Pro Specs
    Beam Pattern:Spot
    Housing Color:Black
    Lens Color:Clear
    Light Quantity:1
    Lighting Modes:High Beam/Dimming Feature (20%)
    Lighting Quantity:4
    Lighting Technology:Cree XP-L LED
    Product Type:XL Pro LED Light Pod
    Universal or Specific:Universal
    Wattage (W):41.400
    So in conclusion, does size really matter? Yes, it does. If your goal is to be able to get more distance the larger XL series reflectors will increase the lights' travel distances over the smaller Squadron reflectors. Both of these packages have great performance for what they bring to the table. Squadron Pros work great if you are looking for a more low-profile light that will pack a punch. The Squadron Pro will give you more near-field lighting but If you are looking to get a little bit more distance the Xl Pro will provide that extra boost while off-roading. Want to see us compare other models or other lights? Feel free to tell us down below.
    Squadron Pros:
    XL Pros:
    !!!WE HAVE LIGHTS IN STOCK!!!
    !REACH OUT TO ME DIRECTLY FOR A FORUM MEMBER SPECIAL!
    Mater likes this.
