Sqeak/Creaking rear window
Discussion in '2.5 Gen Tundras (2014-2021)' started by Icematt, Aug 15, 2018.
  1. Aug 15, 2018 at 11:25 AM
    Icematt
    Icematt [OP] Toyota4life
    Black 1794 TRD
    Fuel wheels
    My 2016 rear window creaks/squeaks pulling in/out of my driveway. Is there any way to grease the rear window? Thanks
  2. Aug 15, 2018 at 11:27 AM
    15whtrd
    15whtrd Mr. Blonde
    My front window has a slight squeak or click when rolled down about an inch. It only happens over bumps. When I push on it it stopped making the noise. I’ve wanted to take it in but figure they won’t do jack shit.
    joonbug likes this.
  3. Aug 15, 2018 at 11:29 AM
    Icematt
    Black 1794 TRD
    Fuel wheels
    Thanks, not trying to spend all day at the dealer too.
  4. Aug 15, 2018 at 11:31 AM
    15whtrd
    15whtrd Mr. Blonde
    Have you thought about taking some dry silicone spray to the weatherstripping?
  5. Aug 15, 2018 at 11:32 AM
    Icematt
    Black 1794 TRD
    Fuel wheels
    No, great idea! Thanks
    15whtrd likes this.
  6. Aug 15, 2018 at 11:49 AM
    SloppyJ
    SloppyJ New Member
    NW Arkansas
    2023 Black SR5 Crewmax Long Bed
    Vaseline on seals normally works. Sounds weird but I believe it's the petroleum in it that works to help rehab the seals. I've used it successfully on an old mini firdge when it wasn't sealing correctly.
  7. Aug 15, 2018 at 11:57 AM
    Icematt
    Black 1794 TRD
    Fuel wheels
    Thanks
  8. Aug 15, 2018 at 2:04 PM
    15whtrd
    15whtrd Mr. Blonde
    Sounds like that would work but his seals are still practically brand new. What do you put the Vaseline on, let it sit and soak in and then wipe it off so it’s not all greasy?
  9. Aug 15, 2018 at 6:15 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    I had a side window that would squeak both up and down. There was something on the glass ( sticky but hard to see), and when the window moved it would grab the seal and not allow it to glide smoothly. Good cleaning of the glass cleared mine up.
  10. Aug 15, 2018 at 6:25 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Damn. I’ve got the exact same thing. Only when it’s down about an inch. Thought same thing about taking it to the dealer.
    15whtrd[QUOTED] likes this.
  11. Aug 20, 2018 at 11:24 AM
    BWinter
    BWinter New Member
    Central California
    2018 White 1794, TRD Off Road, 4x4
