Spyder tail lights hyper flashing
Discussion in 'Lighting' started by robzillaaa, Aug 28, 2018.
  1. Aug 28, 2018 at 6:57 PM
    robzillaaa
    robzillaaa [OP] New Member
    So i installed my spyder taillights todays. The turn signals work fine when the running lights are on. When they aren't they hyper flash. I know they might tons of info on here about this. I am hoping someone could lead me in the right direction.
    Thanks,
  2. Aug 28, 2018 at 7:06 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Maybe reverse the direction you plugged the turn signal cable in?
  3. Aug 28, 2018 at 7:07 PM
    robzillaaa
    I tried that. They didn't work at all
  4. Aug 28, 2018 at 7:10 PM
    GiantsFanDan
    Hmm. Not sure. My spyders don't have this problem and I've had them since 2015. Maybe contact the place you bought them from to exchange? Do both sides hyper flash?
  5. Aug 28, 2018 at 7:12 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    You can install a relay to remove the hyper flash. Do you also have led front headlights?
  6. Aug 28, 2018 at 7:14 PM
    robzillaaa
    Yes both sides. I got them from carid.
  7. Aug 28, 2018 at 7:15 PM
    robzillaaa
    I planned on installing the fronts tomorrow.
  8. Aug 28, 2018 at 7:15 PM
    GiantsFanDan
    Oh maybe that's the problem. It's not the new tail lights but new front LED bulbs installed at the same time? The Spyder tail lights don't need resistors by them self but may need them if the fronts have been changed.
  9. Aug 28, 2018 at 7:40 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Hyper flashing is typically caused by less resistance from the leds. You can install a load resistor to fix the hyperflashing. They are cheap to get. I had to do this to my Jeep when I installed all leds for the brakes and headlights. 1767D295-2ECF-4410-A778-74348EF9426A.jpg
    Sas likes this.
  10. Aug 28, 2018 at 7:43 PM
    robzillaaa
    What size would i need? Do i need to install them on both rear blinkers? Headlights too?
  11. Aug 28, 2018 at 7:43 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Typically you install them on each taillight.
  12. Aug 28, 2018 at 7:50 PM
    1UPPER
    TEXAS
    Flux capacitor!
  13. Aug 28, 2018 at 7:50 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  14. Aug 28, 2018 at 7:52 PM
    1UPPER
    TEXAS
    Flux capacitor!
