Spyder headlights DRL harness
Discussion in 'Lighting' started by Apasion217, Jan 3, 2018.
  1. Jan 3, 2018 at 3:08 PM
    Apasion217
    Apasion217 [OP] New Member
    2016 Magnetic Grey Tundra
    Hi has anyone developed a wiring harness to make the led bar on the Spyer headlights stay on without having to turn on the parking lights? I know it’s been addressed in the past but I don’t think anyone brought it back up. Thanks
  2. Jan 3, 2018 at 6:49 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    I just tapped into an ignition + wire and connected that to the + lead in the LED DRL, so anytime my key is on, the LED bar is on.
    Pudge and Eclipsed & Floating like this.
  3. Jan 3, 2018 at 7:26 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Splice led to red on left and pink on right.
  4. Jan 3, 2018 at 8:08 PM
    Apasion217
    Could you explain a little more? Not quite sure which wires.
  5. Jan 4, 2018 at 3:17 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    OEM wires that go to the factory DRLs/blinkers. I believe there are 3 on each side. They are very thin and a little tough to tap. I used red in line splices.
  6. Jan 4, 2018 at 9:31 AM
    Apasion217
    If you don’t mind, could you post some pictures?
  7. Jan 4, 2018 at 9:34 AM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    and what wire to cut to kill the amber but still have blinker
  8. Jan 4, 2018 at 9:41 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I leave before sunrise and get home after dark during week first opportunity is Sat afternoon. If you go to lighting and find a listing by elodobleu it has everything you need for wiring. I will try to find in a few when eating lunch.
  9. Jan 4, 2018 at 10:52 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
  10. Jan 5, 2018 at 8:55 AM
    Apasion217
  11. Jan 5, 2018 at 5:50 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    The red and pink are splice to my switchbacks on retros. Not sure why that would not work to power Spyder leds. You can also just do an add a tap off the Ign fuse in box under hood to the positive on Sypders
  12. Dec 24, 2018 at 12:43 PM
    vtdeuce
    vtdeuce New Member
    2013 Black Tundra RW
    Apasion217, did you ever figure out how to get the LED bar as your DRL and not the amber lights? I just got the Spyder Gen 2 for my truck and i would prefer to use the LED as my DRL and not have to drive around with my parking lights on all the time...
