Spyder DRL led
Discussion in 'Lighting' started by ATrn, Dec 9, 2018.
  1. Dec 9, 2018 at 5:55 PM
    ATrn
    ATrn [OP] New Member
    2015 Tundra DBL Cab Texas Edition
    I know this has probably been asked a lot, but how can you make the led bar on Spyder Headlights stay on without actually having to turn on the headlights?
    Thanks in advance!
  2. Dec 10, 2018 at 9:43 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Move the power wire from the drl bar to the fusebox and tap into the ign fuse. Use "add a tap" wire to achieve this.
    So basically, extend the 12v+ wire for the drl from both headlights. Solder them into 1 wire. Then extend that 1 single wire to the fuse box.
    Solder or crimp in the "add a fuse" wire to that single drl wire.
    Remove ign fuse.
    Insert add a fuse
    Replace fuse cover
    Done. Now you have drl whenever they key is in the ignition.
    ATrn[OP] likes this.
