Spyder black DRL projector headlights
Discussion in 'Lighting' started by VAQuicksand, May 23, 2017.
  1. May 23, 2017 at 1:25 PM
    VAQuicksand
    VAQuicksand [OP] New Member
  2. May 23, 2017 at 1:26 PM
    Same body style. Should not make a difference unless you have the plat with the led outlining lights
  3. May 23, 2017 at 1:38 PM
    niru316
    niru316 New Member
    2017 Tundra TRD Pro CrewMax
    o_O may have to add these to the list of headlights i'm considering to get lol if you get these make sure to post some pictures with them installed
  4. May 23, 2017 at 5:28 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    They will fit. Output not any better than stock bUT an inexpensive option to increase it is in the works for me. They should show up in the next few days or so. They look good and I'm not unhappy with them as is even if didn't order more powerful HIDs. There are a lot of guys that just plug and play but some of us made the factory levelers work....
  5. May 24, 2017 at 6:38 AM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    So if I don't care about the factory level adjustment, I can just plug and play these? I noticed a note at the bottom of the product page stating they dont working with the leveling models. Guess that means they fit, they just wont level.
    Thanks!
  6. May 24, 2017 at 9:09 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    These are plug n play. I think I've seen someone transfer the leveling motors to the spyders but if not you can still manually adjust these at the headlight.
    I replaced the bulbs with some LEDs and love them
    Jsena likes this.
  7. May 24, 2017 at 9:54 AM
    VAQuicksand
    Spoke with Spyder late yesterday. They said that these headlights are NOT compatible with the 2017 tundra, and it is not recommended.
    Here is the specific statement:
    "Unfortunately we have not test fitted the 2017 model at this time so we
    can't confirm its fitment and compatibility."
  8. May 24, 2017 at 10:11 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    No changes in body style '14 - '17 so these should fit. Sounds like spyder just hasn't confirmed it on their end yet just to make sure they dont false advertise.
    If anything you could order them from a site that states they work for the '17s and if for some reason they aren't compatible you should be able to get your money back
  9. Jun 8, 2017 at 12:10 PM
    dmeneses1983
    dmeneses1983 New Member
    Dennis
    2016 Silver Tundra
    Love the spyder headlights
  10. Jun 10, 2017 at 7:31 AM
    walter93
    walter93 a Newbie: speak slowly and use small words
    Walter
    Houston
    2017 White Tundra SR5 crewmax 4x4 5.7
    TRD air filter TRD air maximizer TRD dual exhaust Gatortraxx MX rolling tonneau cover
    When do the DRLs come on? With parking lights on? With all lights switched off? With headlights on?
  11. Jun 10, 2017 at 9:11 AM
    Eclipsed & Floating
    Voluptuous Whitey
    They fit and the leveling motors work in them. I have it set up that way. Don't believe SPYDER. Trust
    KB Voodoo and PaulROahu like this.
  12. Jun 17, 2017 at 5:37 PM
    KB Voodoo
    KB Voodoo New Member
    Chad
    2017 Tundra Pro Crewmax, Cement
    Many KB Voodoo Fabrications accessories!!
    Much better output than the stock lights?
  13. Jun 19, 2017 at 4:49 AM
    VAQuicksand
    After reading mixed reviews, I never bought them. Didn't want to chance it, maybe someone else can share their experience. Thanks
  14. Jun 19, 2017 at 5:15 AM
    KB Voodoo
    Chad
    I'm on the fence as well.
    They seem too inexpensive to be of high quality. Normally good lights cost a pretty penny. You get what you pay for with lighting.
    I've also read that output is on par with stock. I'm looking for something that blows the stock lights away, but still has a sharp low beam cutoff.
