Springing
Discussion in 'Suspension' started by Samoan Thor, Nov 8, 2017.
  1. Nov 8, 2017 at 1:40 PM
    Samoan Thor
    Samoan Thor [OP] God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    What is the benefit of a spring under? Are these better over the deaver K37 or the new U738(not correct I think)?
    TheBeast likes this.
  2. Nov 8, 2017 at 4:08 PM
    TheBeast The Beach
    Samoan Thor[OP] likes this.
  3. Nov 9, 2017 at 1:53 PM
    M C M
    M C M New Member
    SUA Has more spring arch, allows for a more progressive leaf pack and more travel. A SOA on these trucks is good up to about 13" of travel but has pretty limited uptravel, a SUA set up is good to about 17" on these trucks and will have quite a bit more uptravel which makes a huge difference in off road performance. SUA requires alot more work though
  4. Nov 11, 2017 at 10:30 AM
    Samoan Thor
    Good point, I've seen them a lot on long travel trucks
    thanks man
    badass, thanks for the info, so it sacrifices payload capacity or no? will it be a good option for a mid travel kit?
    joonbug[QUOTED] likes this.
  5. Nov 16, 2017 at 6:50 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  6. Nov 17, 2017 at 10:41 AM
    Samoan Thor
  7. Nov 20, 2017 at 6:31 PM
    Samoan Thor
    If I go with a SUA setup, do i have to change shocks too? I have oem kings all around, from what I'm gathering SUA is mainly used for high speed desert off road applications correct?
  8. Nov 20, 2017 at 6:58 PM
    M C M
    M C M New Member
    Yes, SUA will require all custom shock mounts. It is designed for the best offroad performance.
  9. Nov 20, 2017 at 7:59 PM
    Samoan Thor
    you make this website worth coming to, thanks
    Ace402, TheBeast and M C M[QUOTED] like this.
