Spring ?
Discussion in 'Suspension' started by tdm850, Aug 6, 2022.
  1. Aug 6, 2022 at 6:20 PM
    tdm850
    tdm850 [OP] New Member
    2021 Toyota Tundra
    I have a 2021 4X4 I have a set of 5100 Im going to install but before I do I would like to get a set of aftermarket springs first. All I see are springs with a lift I would think that I need to go back with stock size because Im using the strut to get the lift? If so does any one have any suggestion.
  2. Aug 7, 2022 at 8:22 AM
    tdm850
    2021 Toyota Tundra
    Im going to be adding a winch and bumper later so I just want to do this once I guess I will have to do some web surfing thanks for the info.
  3. Aug 7, 2022 at 8:39 AM
    BayRunner
    2017 Tundra Platinum
    Alcan springs will build them to your additional weight requirements and whatever height you want, including stock height. They are much smoother springs and in my opinion worth the money.
    Sierradevil likes this.
  4. Aug 8, 2022 at 8:26 AM
    tdm850
    2021 Toyota Tundra
    Thank you So that what I was thinking move the perch down for the longer spring just wanted to see if that made since to any one else and it does again thanks. I will look into Alcan.
  5. Aug 9, 2022 at 7:43 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    If you are changing front end coilovers and need stronger springs I would skip 5100s and get one of the lifted coilover setups. Plenty of good ones to choose from that would handle extra heavy bumper.
    AZBoatHauler likes this.
