Spring Compressor Tool
Discussion in 'General Tundra Discussion' started by Steve6, Dec 30, 2017.
  1. Dec 30, 2017 at 11:58 AM
    Steve6
    Steve6 [OP] New Member
    Tucson
    After watching a couple of youtube videos showing the installation of the Bilstein 6112 and 5160 shocks, it seems that this is a very straight forward process. It also appears that there are a number of fairly inexpensive (less than $50) spring compressors available that would make the project even more affordable than purchasing preassemble 6112s.
    Has anyone here purchased or borrowed a compressor tool to use on the Tundra / Bilstein shock that you would recommend? I saw several tools on Amazon that would probably work but I'd like to know which ones will definitely work before I move forward with doing my own installation. BTW, this is for a 3rd generation Tundra.
    Thanks
  2. Dec 30, 2017 at 12:12 PM
    Do you have an Auto Zone, O'Reilly's, or similar near you?? You should be able to rent/borrow compressor from them and save even more scratch.
  3. Dec 30, 2017 at 12:16 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I purchased the harbor freight one. Time bomb waiting to go off. Scary as the bolts bend with the force. Don’t recommend unless you are an addrenalene junkie looking to risk your life.
  4. Dec 30, 2017 at 12:20 PM
    I didn't mind paying ToyTec a little more scratch to assemble my coil overs. I prefer keeping what body parts I still have left.....
  5. Dec 30, 2017 at 12:23 PM
    There are certain tools I'd never buy at Harbor Freight...
  6. Dec 30, 2017 at 12:23 PM
    Steve6
    Tucson
    Thanks. There's an Auto Zone and an O'Reilly's close by and I will look into the rentals. The Youtube video on assembling the 6112s showed the poster using a spring compression tool that looked fairly basic. A quick search brought up several tools that looked very similar with some costing less than $20. That's what got me thinking about just buying one as long as it works safely. There's a lot of energy in that spring and I wouldn't want to get smacked if the tool lets loose.
    zcarpenter92 and kenomouth64 like this.
  7. Dec 30, 2017 at 12:26 PM
    I wouldn't go cheap on a spring compressor. Most of the auto stores have pretty decent compressors to use or buy..
  8. Dec 30, 2017 at 12:35 PM
    There is a lot of solid advice in here.
    Let me add a little more. Most of the spring compressors at the auto parts store that you can rent, will not fit the spring on the Bilstein 6112.
    Did I use it anyway? Yep, just know that if the spring comes off the bench, there is a lot of energy and it can remove body parts. I only squeezed the spring enough to assemble the top plate, so it wasn’t much. If I was attempting to do the highest setting, I would make sure the kit fits the spring cradles.
  9. Dec 30, 2017 at 12:38 PM
    Having it not fit properly does add some intrigue to the process... Oh man........
  10. Dec 30, 2017 at 12:52 PM
    Steve6
    Tucson
    Thanks. I guess I have the same question about renting or borrowing a spring compressor as I do about buying one. I don't know what size or type I need to compress the 6112 springs.
    There is a Four Wheel parts store in Tucson that was good to deal with when I lifted my Bronco. I may visit them and see what they have to say. The install looked pretty straight forward, especially on a new vehicle where the nuts and bolts aren't rusted yet. I'd like to do this myself so maybe buying preassembled will be the best option.
  11. Dec 30, 2017 at 12:52 PM
    Yes it does, every time the ratchet goes click. :D
    You should see what happens when another wrench falling off a bench while performing this task does. Some jump, some shart.
  12. Dec 30, 2017 at 1:01 PM
    Or see what happens when six F-16s decide to blast your neighborhood on their way back to Buckley AFB.....
  13. Dec 30, 2017 at 1:02 PM
    I tossed most of my spring compressors. The one I had from HF was junk, like what @csuviper said. Only one I have left is a snap on one, and that was a pricy one, but still didn’t fit the spring on the 6112.
    I would either purchase them assembled or buy the right tool for the job. Either way, it will cost more. I would opt for the right tool route. Tools can be reused.
  14. Dec 30, 2017 at 1:05 PM
    ^^^Or Chris....buy this so we can all can come over and use yours. Problem solved...upload_2017-12-30_14-5-39.jpg
  15. Dec 30, 2017 at 1:15 PM
    Where I live now, it happens all the time (south of Air Force Academy). I feel your pain. Lucky for me that is only for another 20 days or less.
    How many beers have you spilled due to these F16s?:D
  16. Dec 30, 2017 at 1:25 PM
    I've still have a good grip although they do have a habit of hauling ass most of the time. The Marine reservists flying F-18's out of Buckley on the weekends really like to show off. Like now.
  17. Dec 30, 2017 at 1:41 PM
    Go Devil Dogs!!!
  18. Dec 30, 2017 at 2:01 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Hey Steve, looks like you're in Tucson. I work out at the base and, if you want, I can take you out to the Auto Hobby Shop.
    They have the right kind of compressor and they'll charge a 1 hour bay charge which I think is $4.
    I'm off till the 8th so I have some free time. Let me know.
    mtntop, 831Tun, boostedtrdpro and 6 others like this.
  19. Dec 30, 2017 at 2:06 PM
  20. Dec 30, 2017 at 2:41 PM
    Steve6
    Tucson
    Thanks for the generous offer. I used to work on DM and I can still go on base with my retired creds. I hadn't thought of the auto hobby shop as I haven't used it in years. Great idea.
    ColoradoTJ likes this.
  21. Dec 30, 2017 at 4:58 PM
    Taco-Blender
    AZ
    2010 DC 4x4
    Well, there you go then.
    They have a compressor like the one in the picture @matluth posted. I used it a while back and was in and out of there in under 30 minutes.
    If you need a hand with anything just holler.
    Cheers
    Black Wolf and mdavis like this.
  22. Dec 30, 2017 at 5:27 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    A quick shart would just be prelim
  23. Dec 30, 2017 at 6:21 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    AutoZone and the like will 99% likely NOT work. The prongs or fingers that clamp on the coil are too thick to actually fit in between the coils and allow the coil to compress and/or be removed especially once the coilovers reassembled at the highest lift adjustment. Just an FYI.
  24. Dec 30, 2017 at 6:22 PM
    :der:
  25. Jan 25, 2018 at 8:11 PM
    csuviper
    Broomfield, CO
  26. Jan 25, 2018 at 9:37 PM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
    I got sick of that cheap-ass crap and bought one of these. No regrets.
  27. Jan 26, 2018 at 3:58 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I buy a case of Coors and stop by my local mechanic. Have a beer or two and bullshit with him while using his wall mounted compressor.
    It may help that he's the only one I use for servicing my vehicles for the last 10 years.
    It's also a 45 minute round trip to pick up a loaner tool that may not work so I don't even bother anymore.
  28. Jan 26, 2018 at 4:55 AM
    Ps3udonymous
    Ps3udonymous Who is the smart ass that changed the title?
    Best way.... beers and two c-clamps.
  29. Jan 26, 2018 at 6:53 AM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    What about using the no spring compressor method used for Tacomas and 4Runners? I have watched a few videos on Youtube, it appears to be perfectly safe with no way for the spring to go anywhere while it is compressed.
  30. Jan 26, 2018 at 4:28 PM
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    I did this with my 4runner, it was trivial. I think I did 5100s and fresh springs on each side in about 1 hour.
