Spring bushing replacement
Discussion in 'Suspension' started by blklimitrd, May 14, 2020.
  1. May 14, 2020 at 2:34 PM
    blklimitrd
    blklimitrd [OP] New Member
    Forrest
    2020 Black Tundra Limited Trd
    Hey guys, I’ve got shackles and poly bushings coming for my Tundra. Do you think I will be able to push the stock bushings out with an air hammer or should I bite the bullet and rent a ball joint press? The truck only has 300 miles on it so I’m hoping nothing is seized yet. Thanks
  2. May 14, 2020 at 5:01 PM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    I would plan on having the balljoint press in hand when you do the job. You can rent for free from autozone
    maybe you get lucky and they slide out easy but not sure. Sounds like everyone struggles with them
    blklimitrd[OP] likes this.
  3. May 18, 2020 at 6:30 AM
    I just did mine over the weekend. I used a balljoint press and an impact wrench. Both slid right out with 94,000 miles on them.
  4. May 19, 2020 at 6:44 AM
    Stig
    Stig New Member
    Not sure you have to bite the bullet to rent a press. Drive to your local auto parts store, pick it up, and return it when you're done. In the end it's free.
