Spray in liner - cover the plastic plugs?
Discussion in 'General Tundra Discussion' started by pro2amendment, Oct 28, 2018.
  1. Oct 28, 2018 at 12:26 PM
    pro2amendment
    pro2amendment [OP] Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    Planning on a bullit liner in about 10 days. Checking on some details.
    Is it common to spray over the plastic plugs in the front wall? Would the plugs even be able to be re-installed back on if removed before the spray? I assume not but not sure if should spray over them.
    The few threads I found seem to be sprayed over them.
    Thx!
  2. Oct 28, 2018 at 3:02 PM
    wigsplitter
    wigsplitter New Member
    DFW Texas
    2018 SR5 TSS Crew Max
    bought both my 2013 and 2018 with liner already sprayed in. Both of them sprayed over the oval plugs on the front of the bed.
  3. Oct 30, 2018 at 4:59 PM
    rodm1
    rodm1 New Member
    Consider having the bed rails coated to.
  4. Oct 30, 2018 at 5:25 PM
    15whtrd
    15whtrd Mr. Blonde
    Maybe he’s talking about the top of the bedsides. I wish I would’ve popped the caps off of mine so that it could be sprayed and then reinstalled afterwards.
    NewImprovedRon likes this.
  5. Oct 30, 2018 at 6:53 PM
    JoeDenver
    JoeDenver New Member
    Joe
    Denver
    2018 Crewmax MGM
    Lomax Tonneau, Line-X Bedliner, Clear Mask, Chrome Tip Exhaust, Stubby Antenna
    Not real sure about the plugs but I the wish they would have done the bolts like the factory liner on my first Tundra. Get the bolts done. They said if you needed to take the bed off it’s easier. I said if I have to take the bed off I’m getting rid of the truck..
    Blueknights75 likes this.
  6. Oct 31, 2018 at 2:17 AM
    pro2amendment
    Indiana
    Bullet liner
    Cool. Thanks all for the input!
    I had planned to cover the bolts , except tailgate cover
    For the bed rail caps, will the covers go back on afterwards? I hadn't looked at how those are installed or how easy to remove and put back on. ..
  7. Nov 11, 2018 at 1:01 PM
    pro2amendment
    Indiana
    Bullet liner
    Just an update. They removed the plastic plugs before spraying so the plugs can go back on after the coating
    NewImprovedRon and 4x4_Angel like this.
