Spinning computer drive sound???
Discussion in '3rd Gen Tundras (2022+)' started by TundraDan723, Nov 24, 2023.
  1. Nov 24, 2023 at 8:37 PM
    TundraDan723
    TundraDan723 [OP] Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    When I first start my truck I hear something that sounds like a spinning computer drive. Sometimes it seems to "run" longer than other times.
    What is making this sound?
  2. Nov 24, 2023 at 9:09 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    I haven't yet heard truck sound comparison to computer drive sound.
    Are you referring to a CD-rom drive, or floppy drive, or hard drive? If hard drive, do you mean when it spins up or the clicking sound when its dying.
    Why not post a YouTube link with that specific sound? It's hard to imagine without hearing it
    IT here...
  3. Nov 24, 2023 at 9:23 PM
    TundraDan723
    It sounds like a hard drive or maybe a CD rom drive reading/writing data. I'll see if I can capture it and post on YouTube.
  4. Nov 24, 2023 at 10:57 PM
    Siopao
    Siopao New Member
    Paolo
    2023 Tundra Limited
    Cut and clamp carven exhaust
    Today i actually heard an electronic sounding buzzing by my rear passenger tires while my truck was off. 1st time ive heard that and it stopped as soon as i started my car. Wonder if its related to the campaign ith the e-brakes that just came out on my toyota app.
  5. Nov 25, 2023 at 4:47 AM
    TundraMoe
    TundraMoe New Member
    2023 GMC Sierra Denali 3.0 Duramax
    I’ve heard this three times too in 1.5 years of ownership. It sounds like it comes from under the truck bed inside of the rear passenger tire area. Fuel pump?
  6. Nov 25, 2023 at 4:55 AM
    Evap system self-check
    Buildn, 22whatwedo and pwpblue like this.
  7. Nov 25, 2023 at 4:58 AM
    TundraMoe
    Can you elaborate please? I’m not a mechanic and am not familiar with what you are referring to. Thanks.
  8. Nov 25, 2023 at 5:03 AM
    The 07 to 21 Tundra would, on its own, perform an Evap System self-check. 22's and up probably does it too. That's the buzzing sound you hear.
  9. Nov 25, 2023 at 5:05 AM
  10. Nov 25, 2023 at 5:07 AM
    TundraMoe
    pwpblue likes this.
  11. Nov 25, 2023 at 5:08 AM
    :fistbump:
  12. Nov 25, 2023 at 6:05 AM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    01 Tundra SR5, 02 Sequoia SR5, 23 Tundra Limited double cab
    The sound you are hearing is most likely the D4S fuel injection system. When first started, particularly when engine is cold, it runs on direct injection mode for several seconds very rich using very high pressure which makes a significant amount of buzz or clatter. It then switches to port injection and quiets down. Normal operation.
    This is done momentarily on a cold start by many manufacturers to help warm and fire off the catalytic converters downstream of the engine quicker for reducing emissions.
    Mattedfred likes this.
  13. Nov 25, 2023 at 6:06 AM
    xc_tc
    xc_tc New Member
    Passenger side is where the fuel tank is located too.
  14. Nov 25, 2023 at 6:13 AM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    The fuel tank is on passenger side along with it's evaporative emission or vapor storage system. At times when it performs it's system test you may hear a slight buzzing sound. BUT, on modern Toyotas the evaporative test is only performed after engine is off and sat for few hours to stabilize temperatures and vapor pressures
    Mattedfred, Siopao and Black Wolf like this.
  15. Nov 25, 2023 at 7:17 AM
    TundraMoe
    That makes sense. The noise I have heard is after the truck has sat for a while, not at start up.
  16. Nov 25, 2023 at 8:27 AM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Yeah, you should hear my wife’s Subaru doing that. I thought it was going to blowup the first time I heard it.
  17. Nov 25, 2023 at 8:45 AM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    Gen 2.5 surveillance equipment so they can keep up to date on Gen 3's?
  18. Nov 25, 2023 at 8:45 AM
    TundraMoe
    Wasn’t sure where you were going with that statement 6 words in…
  19. Nov 25, 2023 at 10:04 AM
    22whatwedo
    The Open Road
  20. Dec 22, 2023 at 1:03 PM
    WinLevers
    WinLevers New Member
    I hear the same thing too. It sounds like an old Mac starting up, I swear theres a hard drive in the console.
  21. Dec 22, 2023 at 1:06 PM
    DRP
    DRP Old Member
    Dave
    It is an old Mac. How do you think they get Car Play to work?
    901tundra and 22whatwedo like this.
  22. Dec 22, 2023 at 5:39 PM
    WinLevers
    Touché, my friend, touché!
  23. Dec 22, 2023 at 8:27 PM
    TundraDan723
    Ha!!!
    yes, I should have said it sounds more like the head of a floppy drive or a CD rom moving back and forth.
    It’s random and happens so fast I can’t get my phone in video mode before it stops.
  24. Dec 26, 2023 at 5:04 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    I’ve noticed the radio amplifier has a cooling fan too. Sometimes after shutting the truck off you can hear the fan for a short bit continuing to cool the amp. 2016 Tacoma and a couple GMCs had the same.
    WinLevers and TundraDan723[OP] like this.
  25. Dec 26, 2023 at 5:06 PM
    TundraDan723
    Good to know. I usually notice it upon startup but will keep my ear out for it after shutdown as well.
