Spin-On Oil Filter Adapter - Baxter Performance
Discussion in 'Other Toyota Vehicles' started by co2owen, Mar 19, 2021.
  1. Mar 19, 2021 at 1:46 PM
    co2owen
    co2owen [OP] New Member
    VA
    2020 Cement Limited CM TRD Off-Road
    Trans Cooler. 5100's up front at mid-setting. ESP Plastic Storage.
    I just received this spin-on oil filter adapter from Baxter Performance (baxterperformanceusa.com) for my wife's '17 Highlander. If I like it enough, I'll be buying one for my Tundra before I mess with the cartridge filter again. Her Highlander is the "test mule", don't tell her I said so :). This thing appears to be very well built and is a solid piece; it must weigh close to 5lbs. Baxter Performance's Kevin Baxter said I should pair it with a WIX 51335 or Napa Gold 1335 filter (both manufactured by WIX from what I can tell). She's due for an oil change so it'll be installed in the next couple weeks. IMG_0047.jpg
  2. Mar 19, 2021 at 1:52 PM
  3. Mar 19, 2021 at 2:00 PM
    Rocko9999
    Rocko9999 New Member
    I don't think they make one for our v8 engines.
  4. Mar 19, 2021 at 2:21 PM
    co2owen
    VA
    Part number: TS-301-BK works with the Tundra's 5.7L V8. Kevin Baxter recommended one of the following two filters should I go with the Tundra adapter: Mobil 1 M1-209A or WIX 5156XP.
  5. Mar 19, 2021 at 2:23 PM
  6. Mar 19, 2021 at 2:26 PM
    co2owen
    VA
    YardBird likes this.
  7. Mar 30, 2021 at 2:06 PM
    co2owen
    VA
    Installed the Baxter Adapter on my wife's Highlander this past weekend. Followed Baxter's instructions and torqued the adapter to 40lb/ft and then spun the Wix filter on. She has driven it for a couple days and hasn't had any issues. The Wix 51335 is a shorter filter than most other spin-on's I've used in the past, but Kevin Baxter said it still has more filter media than the stock Toyota filter has.
  8. Mar 30, 2021 at 4:09 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    May I ask why?
    The cartridge filter change is super easy and oil does not go everywhere?
  9. Mar 30, 2021 at 4:56 PM
    co2owen
    VA
    Good question. Unfortunately, I’ve cracked my wife’s filter housing on her Highlander and I’ve also cracked my Camry’s housing. Both were on so tight from the dealer that I got them to cover the replacements. I know I can buy an aluminum OEM housing but I wanted to try a different route. I had to use a 3ft breaker bar to free up the housing this past weekend and I was the last to install the housing at 10lb-ft. This leads me to believe they may tighten up or seize a bit over time but I’m not sure. So far I’m happy with my alternate route, but it wasn’t cheap. If I encounter any problems I’ll let everyone know.
  10. Mar 30, 2021 at 5:10 PM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    I was just looking at a remote filter kit for Tundras.
    Adapter goes onto original filter location with a couple of oil lines.
    Mount the remote adapter inside the engine compartment or frame.
    You can get a single filter or a double filter adapter.
    Around $70.00 for the single and $110.00 for the double.
    co2owen[OP] likes this.
  11. Mar 30, 2021 at 5:27 PM
    Nowhereman
    Al
    Monterey Bay area
    All these nightmare stories I'm hearing can drive a person to drink...
    Hbjeff, WILLINH and YardBird like this.
  12. Mar 30, 2021 at 8:19 PM
    Sancho1
    Sancho1 New Member
    Army Green 2020 Tundra Pro
    So does anyone have experience with these on a Tundra? When you remove the filter for the next oil change will the whole unit come loose if the filter is on tight?
  13. Mar 30, 2021 at 8:41 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I know most of us here are used to the simple twist off filter with our other vehicles, but with a few simple tools and the switch to the aluminum case (if you want), its not difficult at all. Never in a million years would I pay $200.00+ for changing over to the old style for a problem that doesn't exist other than to take a few more minutes for something as important as changing your oil correctly.
    JackBlue, Gravy and JohnLakeman like this.
  14. Mar 31, 2021 at 5:40 AM
    Nowhereman
    Al
    Monterey Bay area
    I don't like the idea of crawling under the truck to change filters anymore (being 68 does that to you).
    Spin on filters are simpler to deal with thus, the most common type used on engines.
    If heavy work is the norm for your Tundra and engine life is always front row, twin filters adds capacity and cleaning to that motor.
    Both two important things in engine life.
    NewImprovedRon and WILLINH like this.
  15. Mar 31, 2021 at 5:57 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    You got that right. Not in a million years. Too many additional opportunities for vulnerability, leakage, and failure.
    But, the aftermarket has something for everyone...I wonder if they considered these in TRD logo? :D:
    https://www.amazon.com/Rhinestone-A..._1?_encoding=UTF8&refRID=E2S9AYB6TRF95PS12E0X
  16. May 15, 2021 at 2:38 PM
    badmotofing3r
    badmotofing3r To be so civilized, one must tell civil lies
    Zach
    Wyoming
    Hot Tamale
    Toytec lift and the works
    I have had mine for about 2.5 years now. I have not had any problems with the whole assembly coming loose.
    I actually had less problems with this setup than the stock setup. I never had a problem with the stock setup until I believe I got a bad o-ring in my NAPA Gold oil filter kit. I should have taken pictures but upon investigating the oil on my garage floor - the O-ring was no longer an “O” but rather smashed flat.
    It could of been operator error but I doubt it.
  17. Mar 13, 2022 at 5:37 AM
    Bigbird57
    Bigbird57 New Member
    The Baxter system let's you use premium filters of your choice. The factory sets do not have anti drain back valves.
    Update: The TRD PRO Oil filters have the anti drain back valve. This is what I run. On second thought, I will replace the plastic cap an get an aluminum cap. < $30.
    Filters are around $14.
    bulldog93 likes this.
  18. Mar 13, 2022 at 5:46 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Would this fit with a skid plate?
  19. Mar 13, 2022 at 5:51 AM
    badmotofing3r
    Zach
    Wyoming
    Hot Tamale
    Depends which skid plate I’m sure. But I can confirm it works with both the stock TRD Off Road skid plate and the aftermarket RCI skid plate WITH a slight modification.
    RitcheyRch likes this.
  20. Mar 13, 2022 at 1:31 PM
    badmotofing3r
    Zach
    Wyoming
    Hot Tamale
    Not all RCI’s require a modification. My friend Quaid (not on forum) has a 2011 with an RCI skid plate and has no issues with clearance and such.
    I on the other hand with my skid plate had to modify the hex bolt for the little oil filter access door. Their bolt was a little long and came close to the oil filter.
    All I had to do was swap the bolt out for a shorter one.
    I also went with a shorter filter. Just to give myself that much MORE clearance. The filter cross reference I’ll have to get back to you on. If I remember correctly it’s the same filter used on the 4.7 Toyota engines.
    Please ignore the oil mess on the skidplate. Different angle of the filter housing but the Toyota filter is a bit shorter.
    Tundra18overland and bulldog93 like this.
  21. Jun 3, 2022 at 9:54 AM
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    Just had oil and filter changed and wondering if you have to drain the system to install the Baxter spin on filter adapter assembly?
    badmotofing3r likes this.
  22. Jun 3, 2022 at 10:08 AM
    millerstone
    millerstone New Member
    2017 TRD Pro DC Cement
    I'm sure it does as it requires removing the stock filter housing and filter.
