Spilled Coffee and Now Heat Won’t Turn Off
Discussion in '2nd Gen Tundras (2007-2013)' started by papatc123, Mar 14, 2021.
  1. Mar 14, 2021 at 5:50 AM
    papatc123
    papatc123 [OP] New Member
    Hi, accidentally spilled some coffee on my climate controls in my 2010 crewmax and now the defrost won’t turn off and lights went out on climate control unit... anyone else ever have this happen? If so any fixes? Does the whole unit need to be replaced? Or is there something behind the face that needs to be replaced rather than the control face. Thanks in advance for any help or insight. Such a bonehead mistake on my part.
  2. Mar 14, 2021 at 5:52 AM
    What year Tundra?
  3. Mar 14, 2021 at 5:53 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    It's easy to pull them out. Lots of YouTube video. Pull them out and clean it and see. Disconnect the battery first.
    1lowlife, Danny3737 and Black Wolf like this.
  4. Mar 14, 2021 at 5:54 AM
    papatc123
    Sorry... 2010
    Black Wolf likes this.
  5. Mar 14, 2021 at 5:57 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Liquids are a great conductor of electrical current. It may stop when the coffee drys up. You can also try blowing some compressed air to dry it quicker. I’d try that first before you spend any money on parts. There are also some aerosol die-electric sprays you can try as well, also called contact cleaner. I hope It’s something simple
  6. Mar 14, 2021 at 6:00 AM
    papatc123
    Thanks so much! I am about to head out and see what I can find. Hopeful it is simple. Can’t believe the quick responses. Thanks!!
  7. Mar 14, 2021 at 6:02 AM
    Ditto on trying contact cleaner first. CRC is good.
    Danny3737 likes this.
  8. Mar 14, 2021 at 6:03 AM
    Danny3737
    I just Joined this forum a month ago and everybody on here is great! Most auto parts stores carry contact cleaner. Some office supply place too
    T-Rex266 and D4x4TRD like this.
  9. Mar 14, 2021 at 2:45 PM
    papatc123
    So I had the whole thing apart and dried, used some crc on the connection points and the heat was still going full blast when I reconnected everything. I discinnected the battery one more time and was able to get it to turn off, but now I have no heat or AC... no power to the climate controls at all. Any other suggestions? I fear I burnt the control board. Thanks again for all the help given so far!
  10. Mar 14, 2021 at 4:57 PM
    Danny3737
    Sorry to hear that. I’d give it another 24 to 48 hours just in case it’s not completely dry yet. You may try disconnecting the battery one more time for at least several minutes. Hopefully you didn’t cook the board. Good luck
