Spiker Engineering Lower Ball Joint Bolt Test (1st Gen)
Discussion in '1st Gen Tundras (2000-2006)' started by NickB_01TRD, Aug 19, 2022.
  1. Aug 19, 2022 at 11:34 PM
    NickB_01TRD
    NickB_01TRD [OP] You don't need less cars, just more driveway.
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Website link
    EDIT:
    00-01(02-04 no protector) OEM "green" bolt PN 9008010066 Torque to 59ft-lbs (SINGLE USE BOLT ONLY)
    00-03(04) ARP bolts (stronger but higher cost) 663-1004
    00-03(04) "Black" bolt for use with protector only 9011910933 Torqued to 37ft-lbs
    04-06 PN 9010512316 Torqued to 59 ft-lbs according to @shifty`. Spiker states up to 80ft-lbs is also ok.
    The parenthesis around 04 is due to the fact that during that year they changed styles. You'll have to determine which style you have in order to know what bolts you need. Looks like production date may be 09/2003 but would need to confirm.
    Here is the original post from Spiker Engineering about their ball joint bolt test
    https://www.instagram.com/p/CgLN4b9pNRQ/
    Second post
    https://www.instagram.com/p/CgcwU1ePqDT/
    And the most recent posts with actual data about each bolt.
    https://www.instagram.com/p/ChdEav7PidW/
    Here is a link to their website as well with more details and such. Didn't actually notice the website till this third post. Website link
    What I gather from this is I should probably replace my "green" bolts that I've used 4 or so times with something else. First that comes to my mind is the "black" Toyota bolts but they appear to be longer. May end up with the ARP bolts
    Website link
  2. Aug 20, 2022 at 3:05 AM
    NetGnome
    NetGnome New Member
    NJ
    2003 RC V8 4wd, 2007 Sequoia V8 4wd
    Removed lots of rust.
    Thanks, this is just what I needed.
  3. Aug 20, 2022 at 4:01 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Do all 1gt's have the 'protector'?
  4. Aug 20, 2022 at 4:24 AM
    NickB_01TRD
    Nick
    KY
    Believe it looks like this.
    I can't find a pic with one installed. I'm not sure when they started running them but I do know my 01 doesn't have one.
  5. Aug 20, 2022 at 4:32 AM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Thanks for sharing this post. This is telling me I should likely replace my flange bolts more often due to the degradation.
    I think they just come on the 04-06 ball joints, a few other earlier trucks reported not having them. My truck has them. I ordered a new set when I bought new LBJs, but the new LBJs came with them installed, so now I have a spare set of protectors.
  6. Aug 20, 2022 at 4:57 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Thanks for posting.
    They did a great job explaining their methodology and what was happening.
    I’ve always thought of bolt degradation and as a result of high torque — like head bolts.
    But their study clearly demonstrates that it happens at very low torque.
    It makes me question the integrity of bolts that get repeated torque cycles, like brake caliper bolts, lug bolts, etc.
  7. Aug 20, 2022 at 5:51 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I deleted the Instagram app a while back so I'm not sure if I can see everything done in the tests. Let me know what f you eventually find a link to what could be considered better bolts.
    spiker likes this.
  8. Aug 20, 2022 at 6:05 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    My '02 has 'protectors'.
    FirstGenVol and des2mtn like this.
  9. Aug 20, 2022 at 6:40 AM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    As good a reputation as ARP Has for head studs in the diesel world. I’d have no issues using there bolts in a lbj application.
  10. Aug 20, 2022 at 7:00 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    So from what I've gathered is that I had the wrong torque spec when I did mine? Black Toyota bolts, not sure on markings as I don't have the truck right now. I thought the spec was 59 ft/lbs for a 2006.
    Does this mean the bolts are compromised? Pretty sure I got the specs from the FSM pdf. Ugh.
  11. Aug 20, 2022 at 8:21 AM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    According to a previous picture I posted on ball joints, mine have the two hash marks on them but they are not black bolts so that just makes this a little more confusing for me. I don't know why this has to be so confusing from Toyota, whether it's a misprint in one manual or what. I'd like to know if we could get it straight answer. I know every year is a little different but man this is a pain
  12. Aug 20, 2022 at 8:25 AM
    des2mtn
    SW
    Tonto cover
    I've always used the 59 ft/lb torque spec. It makes sense to me that the thicker bolts would have a higher torque spec.
    FirstGenVol likes this.
  13. Aug 20, 2022 at 9:35 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Yea, if i'm gonna do everything, i think i want the '05-06 bigger bj's.
    grodiness of '02 in tx.
    Even considering sending money to CA for those solo arms.
    G_unit3000 likes this.
  14. Aug 20, 2022 at 9:47 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Pretty sure someone said the bigger BJ's won't work on our older 1st gens. Different design.
    Jsim likes this.
  15. Aug 20, 2022 at 9:48 AM
    des2mtn
    SW
    Tonto cover
    https://www.youtube.com/watch?v=xPlqLHcphyw
    Weagle and Mr.bee[QUOTED] like this.
  16. Aug 20, 2022 at 9:59 AM
    des2mtn
    SW
    Tonto cover
    I'm pretty sure all that's different is the spacing of the LBJ bolt holes on the spindle. I picked up a spare set of big ball spindles from @Hi06silver awhile back.
  17. Aug 20, 2022 at 10:03 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    stock lca's? Ive seen than the arms and spindles are different ac/dc.
  18. Aug 20, 2022 at 10:04 AM
    des2mtn
    SW
    Tonto cover
    Oh duh, those too.
  19. Aug 20, 2022 at 1:23 PM
    NickB_01TRD
    Nick
    KY
    There is a website link in there. I had it in the middle but just added it to the beginning and end. Link
    From what they stated in their studies if you used the black Toyota bolts (90119-10933) then yes technically they should have stretched if you went to 59ft/lbs.
    It is right unless you're using black bolts (90119-10933)
    FirstGenVol[QUOTED] likes this.
  20. Aug 20, 2022 at 6:42 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    So...having Toyota bolts, with the 2 hash marks not being black bolts is 59lbs from your interpretation? I have the hash marks but they ain't black bolts..zinc maybe?
    Still don't know why they made this so difficult. Maybe it was the study above making me overthink. I torqued to 60-61 ish ft/lbs. Do.t.wanna be worried. I think they should fucking straighten this out if they keep having recalls on ball joints no matter the manufacturer.
  21. Aug 20, 2022 at 6:50 PM
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    Yeah lemme tell you I've been really confused about these bolts in the past few days. Ordered some 90080-10066 from my dealer using my VIN number, and they are most definitely too thin for the thread in my spindle.
    Also ordered 90105-12316 and they worked. However they are different from the bolts I pulled out of my LBJ on my truck this week. And yes I have a double cab that I believe had the LBJs replaced.
    Bolt I pulled out is on the left. The thick shank on it really inspires confidence. Grade 10.
    Center bolt is 90105-12316. No shank, red hue in threads (really light application of loctite?), Grade 11.
    Right side bolt is 90080-10066. Too small for the spindles on my truck.
    Wish I could figure out what the part number of the shanky ones is.
    Jsim and G_unit3000 like this.
  22. Aug 20, 2022 at 11:28 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    For the 05 AC I see these two listed:
    90105-12284 (08/2004 - 11/2004)
    90105-12316 (01/2005 - )
    04 DC lists:
    90105-12284
    04 sequoia lists:
    90105-12284 (09/2003 - 07/2004)
    90119-10933 (02/2001 - 08/2003)
    Edit: 90105-12284 supercedes to 90105-A0187.
  23. Aug 21, 2022 at 7:15 AM
    digitalferg
    digitalferg New Member
    Wandering the Wild West
    2006 Tundra DC TRD 4x4
    Pretty cool info from Spiker. Super interesting.
    But wish they woulda tested the later ones the 05-06 1G Tundra got that are a bit larger. The 90105-12316.
    Since they come with the red loctite stuff on them too, I'm just going to assume they will have similar life to the red ones they did test. As in, pretty much single use bolts.
    Jsim likes this.
  24. Aug 21, 2022 at 8:54 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    The bolt on the left looks to be elongated...yes?
  25. Aug 21, 2022 at 11:59 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    That's somewhat of an illusion. The shank is thicker then tapers down just before the threads start. This makes it stronger in shear around the shank.
    For instance driveshaft bolts are made that way, so they're stronger where they need to be.
    Weagle likes this.
  26. Aug 21, 2022 at 9:45 PM
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    It is just longer. Literally sticks further out of the top of the spindle than the new bolts.
    I'd consider also that they're grade 11 like the black bolts in that test. And that they do the same job in the same truck as all of the tested bolts but are way beefier. I'd wager that if your spindle takes the thicker bolts, the you probably don't have anything to worry about.
  27. Aug 22, 2022 at 2:59 PM
    digitalferg
    Finally just got my hands on a copy of the 05-06 FSM. FWIW, the LBJ torque spec is listed as 48 ft-lbf
    Good thing I *just* torque'd my brand new LBJs into the knuckle with brand new 90105-12316 bolts less than a week ago at 59 ft-lbs as its the only number i could find (over and over and over) out there on forums. :( All you damn non-DC early model year folks... LOL
    Jsim and HAL69000 like this.
  28. Aug 23, 2022 at 9:33 PM
    NickB_01TRD
    Nick
    KY
    Usually is the ball joints but some people (think usually people doing serious offroading) have had the bolts break before. Recall hearing someone using seat bolts as a trail repair to get home.
    5N0W808[QUOTED] and digitalferg like this.
  29. Aug 23, 2022 at 9:34 PM
    digitalferg
    Def a flaw in the lower ball joint design that can-- and will eventually-- cause it to catastrophically fail.
    Then, IIRC, once the word was out to watch the LBJs and replace them regularly, folks started finding missing bolts and having bolt failures. Which led to finding multiple different replacement bolt part numbers and the debate on whether they could be re-used.
    So, the answer to your question is kinda both...
    des2mtn and 5N0W808[QUOTED] like this.
  30. Aug 24, 2022 at 5:59 AM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    See I was having the same issue. I swear I saw 59ft/lbs somewhere when I did mine.
    After te-reading this study for the 10th time Ive came to the conclusion that as long as you don't have the black bolts 59 is ok.
    As for you're picture, I wonder if that is for a dust cover that the bolts go through? Sorta like the other LBJs with 2 torque specs? I mean my dust cover isn't even a part of the surface where the bolts go in...idk
    Jsim likes this.
