Speedometer with bigger wheels and tires
Discussion in 'Wheels & Tires' started by Kiko, Feb 16, 2015.
  1. Feb 16, 2015 at 6:17 PM
    Kiko
    Kiko [OP] New Member
    Kiko
    Aspen
    Tundra 2014 TRD SR5 crew cab
    3" front 1" back toytec Leveling Kit, dipped bumpers grill, emblems
    Hey guys. I'm putting 33x12.5R20 wheels and tires on my 2014 tundra. I know that it will affect the speedometer and mileage . Any suggestions on how to fix that?
    Thanks
  2. Feb 16, 2015 at 7:14 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    I think the hypertech chip or programer fixes it.
    Bob and Kiko[OP] like this.
  3. Feb 16, 2015 at 7:45 PM
    The hypertech can fix it.
  4. Feb 16, 2015 at 8:37 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Kiko[OP] likes this.
  5. Feb 17, 2015 at 9:03 AM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    I doubt it'll be more than a couple mph off. On my '14 I did 295/70/18's (nitto spec's 34.6") and I'm about 5% off.... 2mph around 40mph, and about 3-4mph off on the freeway. I would check your speed with a gps after installing the tires before spending the money on the hypertech speedo calibrator.
    Joe Dirt and Kiko[OP] like this.
  6. Feb 17, 2015 at 9:25 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I wouldn't worry about recalibrating speedometer with 33 inch tires. From what I read, your speedometer becomes more accurate with 33 inch tires than with stock 32 inch tires.
    Kiko[OP] and Relentless like this.
  7. Feb 17, 2015 at 11:01 AM
    scratchex
    scratchex New Member
    2015 Tundra Limited
    3" lift TRD Exhaust 20" Fuel Lethal Wheels Toyo AT Tires Black Flares w/ spikes
    Would you need to going from 33's to 35's?
  8. Feb 17, 2015 at 1:46 PM
    chphilo
    Western PA
    Yes. Your speedometer will be substantially off with 35. For some reason, vehicles are set so the speedometer reads faster speed than the actual speed. It may have to do with law suits, but I am not sure. For Tundras, 33 seems to be almost spot on with gps speed reading.
    r1-superstar and Kiko[OP] like this.
  9. Feb 17, 2015 at 2:19 PM
    Virgils12
    With my 35's I'm off 3-4 mph.
    scratchex likes this.
  10. Feb 17, 2015 at 2:41 PM
    Relentless
    Eric
    Cant hurt, see my post above.
    Yeah, it's actually a percentage so at low speed it's nearly correct and the faster you go the more mph the gap is from what it should read. On mine it's 3-4 on the freeway (70mph) but only like 2 mph in town (around 35-40mph)
    scratchex[QUOTED] likes this.
  11. Feb 17, 2015 at 3:46 PM
    Virgils12
    This is probably right just never checked it in town before. ^^
  12. Feb 17, 2015 at 5:29 PM
    That changes with speeds
    Take it from someone who was stopped 90+ In a 75 from CSP ...no cite though.
  13. Feb 17, 2015 at 5:30 PM
    A good way to find out is to find one of those portable radars where it displays your speed...or know some fellow LEO friends that'll use a radar or laser to measure Ur MPH :cool:
    Joe Dirt likes this.
  14. Feb 17, 2015 at 5:57 PM
    Virgils12
    There are plenty of speed apps to download on your smartphone also. The one I use is speed box.
  15. Feb 17, 2015 at 6:41 PM
    Relentless
    Eric
    Yes, like I said it's a percentage difference not fixed like some believe it to be.
    Mine as an example seems to be off 5%(verified w/ GPS app) so in calculations......
    Reads----------Actual
    20 mph x 105% =21mph
    30 mgh x 105% = 31.5mph
    40..... 42mph
    50...... 52.5mph
    60..... 63mph
    70..... 73.5mph
    80..... 84mph
  16. Feb 18, 2015 at 1:06 PM
    JMB
    JMB I buy Nickelback albums at Target.
    Chesapeake, VA
    2013 Super White Tundra DC
    Here's a pretty handy calculator.
    http://www.tacomaworld.com/forum/tirecalc.php
    Hypertech will work, or some shops will calibrate. We have a guy local that will calibrate and provide a notarized statement as to how far off it was. Can get speeding reduced to improper equipment.
    T-Rex266 likes this.
  17. Feb 20, 2019 at 7:39 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Digging this one up form the depths...
    This is another reason I didn't go with 295/70-18 for my application.
    OEM size - 275/55-20, the 295/70-18 would put my speedo at a difference of 8% on average. This is a 2.4" difference in tire height, possibly needing a speedo recalibration.
    OEM size - 275/55-20, the 305/65-18 would put my speedo at a difference of 4% on average. This is a 1.4" difference in tire height, perhaps not needing a speedo recalibration.
    The 275/65-18 tire found on the Off-Road models are is 1/4" taller than my 275/55-20 found on my Sport.
  18. Feb 20, 2019 at 7:59 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    As it takes a longer rotation to reach 1 full turn going from stock to a larger tire, I believe % difference higher in circumference is % difference slower on speedo. The bonus your odo is adding up slower too. So if it looks like you are going the max speed limit, you will be speeding according to radar traps.
    Hypertech calibrator is the dash fix. GPS based speed app on a mounted smartphone is the cheap fix. Guys with android HU's of any sort can install home screens with GPS based speedo.
    r1-superstar likes this.
