Speedometer calibration
Discussion in '2.5 Gen Tundras (2014-2021)' started by DDwyer, Mar 13, 2023.
  1. Mar 13, 2023 at 1:14 PM
    DDwyer
    DDwyer [OP] New Member
    Dillon
    Canada
    2021 Wind Chill Pearl Tundra Platinum
    BDS lift 37" wildpeaks Bilstein 8125 front coilovers(8" lift) Bilstein 5125 rear shocks RoadActive suspension kit Coachbuilder steering kit Carven exhaust
    Hey all! So it's time I get my speedometer calibrated. Lived with it rolling the 35s around but the 37s are putting it off abit much for my likings. I've read numerous times that the hypertech won't work correctly with the platinum trim but I feel there has to be a way I can calibrate it. I can't see how the platinum would differ from any other trim in regards to speedo recalibration.
  2. Mar 13, 2023 at 7:14 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Welcome to the forum. I suggest asking in here https://www.tundras.com/threads/dirty-seven-club.40397/page-65#post-2743269
    Your fellow 37s club members may be able to help.
    Good luck.
  3. Mar 13, 2023 at 7:24 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Trim level is inconsequential. I've got the Rough Country Calibrator which is basically a rebranded Hypertech. I swapped gears and have oversized rubber - you input the revised information and it will still be off so what a lot of guys do is play with the numbers a bit. Try putting in a larger tire size than what you have or smaller size...then run it and see if it gets you more or less accurate then adjust again until it's dead on or within your tolerance.
  4. Mar 13, 2023 at 8:49 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    The reason why is nobody is sure exactly what the baseline is. The ecu is not programmed exactly for the specific tire from the factory but it’s close. Toyota left themselves a “fudge” zone but nobody knows by exactly how much. Your truck maybe have come with 18s from the factory but it’s not programmed exactly to the size of those tires ect.
    Also your new tires may be sold as a 35 but could really be 34.5 or 35.5 in. You get small error on both ends reasons why you have to adjust/play with it until it’s close to GPS readings.
  5. Mar 14, 2023 at 3:40 AM
    DDwyer
    Dillon
    Canada
    I had my 2014 sr5 calibrated using the hypertech module so I understand the process off getting it setup right. I've just heard numerous members now report the module not working with their platinum trim trucks. I myself don't see how trim level would impact it but I figured I'd ask before I place the order.
    texasrho83 likes this.
  6. Oct 1, 2023 at 11:03 PM
    DDwyer
    Dillon
    Canada
    Okay so just to let you all know the module does not work with the platinum trim. Module doesn't support some of the features
  7. Oct 2, 2023 at 4:07 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Lol if true that’s on Hypertech…
    Does it say which features it doesn’t support? The speed data you are correcting is the same on literally every Toyota. Tundra, Sequoia, Camry, Prius, RAV4, Sienna. I have seen CAN logs out of all of them. One thing guaranteed the same on everyone is the speed data.
    Can the module just not handle the traffic load of the extra features. Reading in and correcting the speed is super easy from a programming standpoint.
  8. Oct 2, 2023 at 6:40 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I have an SR5 and still don't get a true reading.
  9. Oct 2, 2023 at 7:29 AM
    DDwyer
    Dillon
    Canada
    I've read other reports of the same/similar issues. My speedometer is corrected mind you and the newest firmware update from hypertech allows you to fine tune and actually enter GPS speeds during the setup. Seems to be mostly issues related to the update that brought toyota safety sense into the picture
  10. Oct 2, 2023 at 7:37 AM
    coTony
    Tony
    Montrose, CO
    I have a 2018 Platinum and have an older Rough Country calibrator I used to correct mine around 4 years ago. I had a lot of trouble getting it to tune in the first time but got it after about a week of messing with it here and there.
    Fast forward to a few months ago when I bought 37's and have yet to get it to program. After numerous attempts, a lot of posts on here and multiple phone calls to Hypertech (Hypertech makes the modules and the software but they are sold under different names although identical, just different $$) I found that the module I have has somehow shot craps and is no longer working.
    I have a new one in the mail under warranty
  11. Oct 2, 2023 at 7:55 AM
    roughfisher
    roughfisher Aggressive hockey is back in town!
    JP
    Northern Minnesota
    2021 MBM CM SR5 TRD OR 4x4
    I installed mine a few weeks ago after I mounted my 35s and it's been working as advertised. Hypertechs youtube video on adjusting the unit is spot on. I had to make one adjustment after the initial guess on tire size, and as was already mentioned the the latest firmware allows you to fine tune with GPS. some have mentioned that the radar controlled cruise doesn't work accurately but I haven't found that to be the case, so not sure what the issue is there. I've been pleasantly surprised that in addition to displaying the correct speedo info, my transmission shifts at the correct shift points again and I've gotten a lot more pep getting the truck rolling than without. I don't notice any difference between rolling with the stock 32s and my 35s now. Way cheaper upgrade than swapping gears. curious how that will translate to 37s though
    coTony and Saltyhero13 like this.
  12. Oct 2, 2023 at 8:09 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    How old is your module? Maybe I can get them to swap mine.
  13. Oct 2, 2023 at 11:05 AM
    coTony
    Tony
    Montrose, CO
    I was out of warranty now but I was in warranty the first time I asked about the problem
  14. Oct 2, 2023 at 1:55 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Did you ever check the use GPS box to calibrate?
  15. Oct 2, 2023 at 1:57 PM
    DDwyer
    Dillon
    Canada
    Okay so update, upon uninstalling to return I removed the zip ties that were on the harness and all my features that had been missing started to work. Seems I had a lose connection or something in the harness. Now onto my next issue... the module is not actually inputting any new correction factors into my speedometer. The program is not reading my device serial number or part number. Waiting on a call back from hypertech now
  16. Oct 2, 2023 at 2:00 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Rough country unit here on my platinum no issues.
