Speedometer and cruise speed don't match
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sleddog, Aug 10, 2020.
  1. Aug 10, 2020 at 4:53 AM
    Sleddog
    Sleddog [OP] New Member
    2019 black Tundra TRD dbl cab
    Has anyone had an issue with their speedometer and cruise control speeds not matching when the cruise control is activated? My 2019 Tundra TRD Off Road has consistently displayed my speed at 1mph less than what the cruise control speed is set at. It's probably not an issue to most people, but my OCD causes it to bug the heck out of me! I thought that maybe the all terrain tires could be causing it, but they are the stock tires that came on the truck and I haven't done any modifications. The only time the speedometer and cruise control speeds match is when I go down a hill. Any ideas on what could be causing this? The truck only has 2700 miles on it so it's still under warranty.
  2. Aug 10, 2020 at 5:02 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Your truck is obviously defective. You should trade it in for a Ram immediately.
    Just kidding, don’t do that. Mine does the same thing. I’m not sure but I think maybe it has something to do with the way the ECU rounds the speed up or down. I choose not to worry about it.
  3. Aug 10, 2020 at 5:07 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The cruise control set speed is the target the CC system tries to achieve.
    Through real world conditions your truck will never hit that speed, and maintain it consistently. There are variations.
    Road conditions, wind resistance, temperature, and more.
    There is no issue with your truck, and odds are there is no "fix." The reality is that we all drive in a "real world" setting where variables are constantly changing. This causes fluctuations in your actual speed reflected by your speedometer. Your CC system will do whats necessary to maintain that speed as close as possible.
    1 MPH difference on speedo vs set speed just means that your trucks cruise control system is healthy, and operating correctly.
    :thumbsup:
  4. Aug 10, 2020 at 5:42 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  5. Aug 10, 2020 at 5:42 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Might also be your Cruise control distance pacing radar slowing you down slightly. You can turn it off by holding in the cruise control on/off button for a few seconds when you turn on Cruise control and that will set your cruise without the distance pacing radar. Try this and see if the issue still exists.
    Tundra2 likes this.
  6. Aug 10, 2020 at 5:46 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Forgot about the radar cruise with my "unadvanced" 2002 :rofl:
    glowblue likes this.
  7. Aug 10, 2020 at 5:50 AM
    nopsFU
    nopsFU New Member
    2019 Tundra TRD Pro
    Interesting! My 2019 does the opposite, 1 mph faster in cruise than the set speed with zero mods. This is my first Toyota and found it odd they couldn't hit the mark on a flat road. I just set my speed 1 mph lower than where I want to cruise and let it go. I'm more pissed about the downshift strategy; the tiniest little hill will cause a 6->5 downshift with minimal payload. Could be worse though, the gov't could regulate those squishy humans out of the driver seat.
    Edit: post your tire size when you get a chance. Mine is P275/65R18. I wonder if the tires offered are 'close enough' instead of accounting for tire size in vehicle speed calculations.
    No clue why there's a difference. Online wheel/tire size calculator shows 629 revs/mile for both 275/65R18 and 255/70R18.
    Sleddog[OP] and BigdaddyII like this.
  8. Aug 10, 2020 at 6:41 AM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    My truck displays actual speed at 1 mph lower than cruise target. Bothers my OCD as well. I set cruise for 1 mph higher than my intended speed and more often than not it will match that speed perfectly. I was convinced my truck was doing that on purpose just to get under my skin.
  9. Aug 10, 2020 at 6:49 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    One my 2020 my cruise control is spot on. It reads exactly the same as the set speed. There is something definitely wrong with your truck and I would take it in and raise hell.
    :rolleyes:
    JLS in WA, jordoncloutier and deptrai like this.
  10. Aug 10, 2020 at 6:54 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Yeah, I noticed this in my 2020 with all stock wheels/tires. It is not 100% consistent though. Sometimes they match, sometimes they don't. When they don't, the cruise target is always 1 mph higher than the speedometer on flat ground. And I ALWAYS use the "Constant Speed" cruise control. I hate that radar crap. I don't like it, but my OCD is not sever enough for it to do more than irk me a little.
  11. Aug 10, 2020 at 7:02 AM
    Sleddog
    Thank you all for the responses. My Tire size is P255/70R18. I don't use the radar cruise. My issue is only with the regular cruise control.
  12. Aug 10, 2020 at 7:03 AM
    Only to tow AS
    Only to tow AS New Member
    2020 Limited CM 4x4
    Picked up truck on Saturday. Drove it 130 miles back home and noticed it was always 1mph lower on flat when using cruise control (radar control).
    20" wheels, no TRD offroad
  13. Aug 10, 2020 at 7:06 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Mine is hit and miss. If on digital speedometer it will be right on or 1 mph off. But the actual speedometer needle always says what the cc is set too. Half the time i set the speedometer when the digital speed is what I want and it sets no problem.
  14. Aug 10, 2020 at 7:28 AM
    glowblue
    VA
    I hate the whole idea with TSS, especially the dynamic cruise control.
    :eek:
    Cpl_Punishment and Bakershack like this.
  15. Aug 10, 2020 at 7:55 AM
    nodak67
    nodak67 New Member
    JR
    depends on when you hit the button to activate the set speed. sometimes i can get it to set at 75 and show actual 74 and at times set it at 75 and actual be 75. it really depends on if you set it at actual 74.x+ or 75.x+
    i think the display is just rounding set and actual down/up depending on actual speed vs set display.
  16. Aug 10, 2020 at 9:05 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I noticed this one time I used cruise control but other times it's been bang on. I don't use cruise often enough to detect a pattern.
    Sleddog[OP] likes this.
  17. Aug 10, 2020 at 10:38 AM
    TomyTun
    TomyTun New Member
    CA
    2016 TRD Off Road, Crewmax, 5.7L Non-FFV
    None
    My 2017 Camry does the same thing.
  18. Aug 10, 2020 at 12:41 PM
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    I had to make a run to Tallahassee this morning. Used my Garmin so I could compare speeds. With my cruise control set at 78, the analog speedometer read 78, the digital speedometer read 77 and the Garmin said 76. This is the eighth Toyota I’ve owned. They have all been a couple mph’s slow at similar speeds.
    Sleddog[OP] and jewsNbrews like this.
  19. Aug 10, 2020 at 12:42 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Mine is always 100% spot on (at least on flat ground!).
  20. Mar 6, 2021 at 8:44 PM
    Ellis42sbgtf
    Ellis42sbgtf New Member
    Kyle
    Houghton, MI
    2018 Crewmax TRD Sport 4x4
    New here. Just curious as to if anyone has an issue with the digital speed and the actual needle on the speedometer not matching about 4mph difference. To make it worse for OCD is that the GPS speed on the phone is lower than both...how can I know how fast I'm actually going. Cruise control seems to agree with the digital speed (didn't compare to GPS because my phone died).
  21. Mar 7, 2021 at 6:21 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Based on the speeding ticket I got, I'm pretty sure my digital speed display is accurate. That was surprising to me as I'm pretty sure the speedos in all my other cars read 2 kph high. I never look at the analogue gauge because I can't see it very well with how I have the steering wheel set.
  22. Mar 7, 2021 at 8:03 AM
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    You got a speeding ticket? What kind of lawless scruffian are you? JK Rosy, have a great day!
  23. Mar 7, 2021 at 8:17 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    You got me! :rofl:
    Turns out the city put a speed camera at the spot on my previous commute where you come down from the "hill" of the freeway overpass then go up the "hill" for the railyard overpass. So I was trying to maintain momentum for good fuel economy. I was also the slowest guy through that area before they put the camera in. Every single person I've talked to who drives there got a ticket at that spot but the traffic coming off the freeway does so at a much more reasonable speed now.
    tttrdpro[QUOTED] likes this.
  24. Mar 7, 2021 at 8:24 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I changed my “home” display to not be the digital speedometer... so I don’t notice the discrepancy. :thumbsup:
    RdKing, tttrdpro and Cpl_Punishment like this.
  25. Mar 7, 2021 at 9:24 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    There's a pretty decent chance your speedometer is off by a little bit too. Check it with a GPS and then your OCD can really kick in. Or, you can just drive it and enjoy it without worrying about it.
    Ellis42sbgtf and Cpl_Punishment like this.
  26. Mar 7, 2021 at 1:47 PM
    Midnight66
    Midnight66 New Member
    Georgia
    2021 Super White Limited/TRD Off RD
    My ‘21 does the same thing - 1 mph lower than setting. And it’s not the related to the radar cruise. I usually turn that off and use constant speed cruise.
  27. Mar 8, 2021 at 11:28 AM
    Yoder18
    Yoder18 Veteran underwater basket weaver
    Mitch
    Front range Colorado
    18 tundra trd off-road
    •Toytec Radflo 3” with 1.5 shackles •+25mm icon rebound wheels matte black. •Prox15 tonneau/Softtopper •315/70r17 ridge grapplers •Wheelers front bumper stops •Spray in bed liner •Vleds floorwell leds front and back and interior led kit •Boss front bumper spacer •First choice fabrication welded sliders •8” ss dirty deeds exhaust •Tech12volts remote start with carlink •Vleds front turn signals leds •AFE pro dry s air filter •Baja xl sport amber fogs •Victory 4x4 strike bumper w hoop •Ajt designs chrome delete for vent rings and cup holder/gear shifter (black) •Wet okole seat covers •Husky floor liners •RCI skid plate and transmission skid •Jomax SpEed sensor guards •Rear diff breather location mod
    I just got back from a trip from Colorado to Idaho and went the Teton mountain route. The only way I found my cruise stays on the set speed is after it’s gone through a few hills and shifting points. Once it found the sweet spot it stayed dead on the rest of the way. Also have 315/70 on a 3” lift.
  28. Mar 8, 2021 at 11:32 AM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    My 2020 does it too. Very annoying. In general, the entire cruise control system (including the DCC) on the Tundra just sucks. My other cars are a 2019 Chevy Impala and a 2018 Honda Accord, both with DCC. Their systems are far and away better than what's in the Toyota. Particularly on the Impala, the DCC works wonderfully. Whereas, on the Tundra, it is jerky and slow to react. GM and Honda just did a way better job with their DCC systems.
  29. Mar 19, 2021 at 9:52 AM
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    My 19' CM digital speed matches the cruise set speed # , I have compared speed with a GPS phone app and my truck reads about 3-4 kph slower than what the GPS says I'm actually doing . Moving up to a 33" tire should solve my speed discrepancy
