Speedo Re-calibration
Discussion in '2.5 Gen Tundras (2014-2021)' started by 53flattie, Jun 7, 2015.
  1. Jun 7, 2015 at 6:12 AM
    53flattie
    53flattie [OP] New Member
    Upstate SC
    2015 SR5 CM 4WD
    2.5" / 1.5" leveling kit ; 275/70/18 BFG AT/KO's
    No - this has nothing to do with a European swimsuit for men....
    I went from 255/70/18's to 275/70/18's, or an increase of about 1" in diameter. Should I have the speedometer re-calibrated to account for this difference? I would like to know that my speedometer is accurate and that my shift points are correct.
    Thanks!
  2. Jun 7, 2015 at 7:34 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Well you kind of answer your own question in your post...
    Though keep in mind a difference of 5% is acceptable from the factory. You now be more accurate than you were before.
    Compare with gps or mile markers.
  3. Jun 7, 2015 at 9:32 AM
    Get the Hypertech Speedometer Calibrator. The higher you are in speed, the greater the speedo will be off.
  4. Jul 9, 2015 at 5:08 AM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    Dredging this back up... I know that the Hypertech is the best option, but it's also quite expensive. It seems like I read somewhere that the dealership can recalibrate for tire size. Can anyone tell me if that's true? If so, I'll ask them to do it at my first service visit.
  5. Jul 9, 2015 at 5:42 AM
    I believe they can, yes...not the cheapest though.
